My car after the lt4 cam kit
Old Oct 1, 2003 | 02:39 PM
  #16
WheelmanZ28's Avatar
Originally posted by LT1Brutus
2. Did you replace the lifters? Some people get away w/out it; however my experience is that a LT4 HC will colapse weaker lifters, and can wearout good stock lifter in about 2-3K miles if you're shifting high or driving hard.
3. Did you adjust the valves right? This can lead to false knock or partially collapsed lifters. If your lifters have any collapse problems, I've seen a 35hp+ hit.
Those two points hit the nail on the head.
Old Oct 1, 2003 | 02:57 PM
  #17
LT1ponykilla's Avatar
I wonder if this could be my problem? I ran the stock lifters cause my buddy did and he has 155k on his car and just put a cam in. His car runs like a raped ape and I still have a huge power loss problem. I also had the RR's to tight that wouldnt let the valves close on cylinder number 1 causing 0 compression on it. I wonder if this screwed up my lifters? If I had a bad lifter, would there be any valve noise? How much are new lifters and which ones should I go with to match the cam in my sig?
Old Oct 1, 2003 | 02:59 PM
  #18
U can get the Comp Cam R or Pro Magnum Lifters (they are referred either way) for only $20 more than OEM Lifters. DEFINITELY worth doing, especially during a cam swap.
Old Oct 1, 2003 | 03:01 PM
  #19
Thanks man! I will look them up on JEGS now! Is there anyway to tell for sure if they are bad before I go and buy new ones?
Old Oct 1, 2003 | 03:58 PM
  #20
Like I said before, it's hard to tell if they aren't severely damaged. If ur powerband is weak up top, that's a sign. If they are just weak, u may get some valve float at high RPMs. Also, ur vacuum pressure will be all over the place. The VP is usually the main culprit.
Old Oct 1, 2003 | 04:18 PM
  #21
Hyperspeed97z28's Avatar
if you spent the cash for the hot cam kit, stop being cheap and send your pcm out to get reprogrammed... its gonna have to get done either way.....
Old Oct 1, 2003 | 04:31 PM
  #22
xxsaint69x's Avatar
since hot cam is such a monster cam and all
planny of people are runing stock lifters with real cams and have no problems
I am guessing you didnt allign the timming chain correctly....did the 2 dots line up PERFECT?
Marcin
Old Oct 1, 2003 | 04:50 PM
  #23
Do you think the XE 224/230 cam could mess up the stock lifters with 90k miles on them? I know its not a huge cam, but it may be big enough. Especially since I have had valve problems with the RR's being to tight.
Old Oct 1, 2003 | 08:37 PM
  #24
Zerocool's Avatar
everything is set up right. hopefully a tune will jsut fix all my probs, i had the stock MAF on it to, didnt change much... im just gonan get a PCMforless, thanks for your guys help. hey where is my ECU? i know its in my box thingy i took apart to replace my knock mod with an LT4 KM, can someone link me to a site that will show me how to pull out the pcm thing i need to send to pcmforless
thanks all
Old Oct 2, 2003 | 12:10 AM
  #25
LT1Brutus's Avatar
Zero, you send the whole box. Alternatively, Bryan (owner of Pcm4less) will charge you $75 extra (core) and send one already programmed out. Then, you swap your KM into the new one, pay ~$12 to send it back to him, and upon delivery, he sends you your $75 back. That means NO downtime.
Saint- I know the LT4HC isn't huge, but it does have considerable lift and the springs are higher pressure. On my 109K mile car I had 2 lifters that kept collapsing. I changed to 20-50 synthetic from 10-30 and the problem went away for about 4,000 miles. Then my times started rising. Suddenly I had better weather and track conditions but was running like 12.3-12.5s. If I loosened the roller rockers then retightened them, the car would drop down in the 12.1-12.2 range. After I got some comp Rs my times went back into the 11s until I hydro-locked the motor.
As for contacting Jegs about the Comp R lifters....officially they are not produced anymore. You may have to call a few places that deal comp cams to find someone that still has some in stock.
Old Oct 2, 2003 | 09:26 AM
  #26
You can get the Comp R lifters from Thunderracing and from Combination Motorsports!
Old Oct 2, 2003 | 12:27 PM
  #27
firstgener's Avatar
cam install
I also just put a hotcam in my car, it fees great. Granted it would run better on a reprogramed computer it still runs past some new ls1s therefore i am happy. I plan on sending the computer off but for now i am loving every minuate of it. I did the swap with 118k on the clock and she runs sronger than ever.
My .02
Austin
Old Oct 3, 2003 | 12:13 AM
  #28
Zerocool's Avatar
i took the ECU out, i barrowed another one from my buddy. im sending it down to PCMSFORLESS, i hope everythign works out good for me.. im goign through so much ahssel with this car grrr.. i hate whoever buys it off of me down the road becuase they wotn have to repalce anythgin ebcuase i have repalced Almost everythign on the car over a span of a year. meh its been a fun but expensive ride. wish me luck.
Old Oct 3, 2003 | 12:20 AM
  #29
S.J.S.'s Avatar
Dude...before you go getting the lifters. GO GET THE REPROGRAMMING!!!! Everyone is basically if not telling you to do so they're saying you will need it. So why don't you go with something you're gonna need then reaching. JMHO.
LeftoverChinese
Jan 14, 2024 03:03 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GigaMp3z
Feb 20, 2003 02:57 PM
