My BFG's are on!!
Old Feb 26, 2004 | 12:11 PM
Cmr0z28's Avatar
My BFG's are on!!
2 salad shooter wheels - FREE
mounting/balancing - FREE (done by myself)
Tires - $283 shipped from www.tbyrne.com
These tires grip so freakin AWESOME! I can't even chirp them! I did about 3-4 launches in an empty parking lot, no chirp or anything, car just jumped straight ahead. I've never experienced the 1st gear torque because if I did that on my street tires, they would just light up and I'd go sideways. I have them at 20 psi now.
http://images.cardomain.com/member_i...1_242_full.jpg
http://images.cardomain.com/member_i...1_243_full.jpg
http://images.cardomain.com/member_i...1_244_full.jpg
Old Feb 26, 2004 | 12:18 PM
Valkyn71's Avatar
Look good, i have a set of Nittos im waiting to put on, anyone know if they offer as good of traction as the BFGs?
Old Feb 26, 2004 | 12:19 PM
Cmr0z28's Avatar
My friend Javier97Z28 cut a 1.66 second 60' time on Nittos, so that should answer your question. As far as I know, the BFG's are a little stickier but not as streetable, and will wear out much faster. I went with BFG's because I'm only using them for the track.
Old Feb 26, 2004 | 12:20 PM
AxeGrinder30thZ's Avatar
Those look nice man. I'm lookin' into them now.
Old Feb 26, 2004 | 12:49 PM
Tair's Avatar
lookin good
Old Feb 26, 2004 | 01:49 PM
96ta(nick)'s Avatar
i need some more nittos mine are shot and i pulled a 2.5second 60' at the track on my crappy big O tires..
Old Feb 26, 2004 | 01:52 PM
WheelmanZ28's Avatar
Nice, I'm still debating switching to them from my Dunlop Sports 5000s. I guess I would feel bad just discarding two expensive *** street tires, considering i just bought them last spring
Old Feb 26, 2004 | 01:57 PM
Cmr0z28's Avatar
I know how you feel.....that's why I got 2 spare rims, and had them mounted on them so I can just swap them out on track day.
Old Feb 26, 2004 | 02:15 PM
383_BluByU's Avatar
how long is your rear-end going to last with those things? or have you upgraded it?
Old Feb 26, 2004 | 02:22 PM
bdc95ta's Avatar
you can discard them my way my frame was messed up and in turn I had to keep rotating my tires. Long story short, need new tires!!
-b
Old Feb 26, 2004 | 02:26 PM
Cmr0z28's Avatar
The stock rear isn't bad when you're running 13s in an A4.
Old Feb 26, 2004 | 06:22 PM
Cmr0z28's Avatar
Heading to the track tomorrow night, it will be 48 degrees! I'll let you guys know what I run
Old Feb 26, 2004 | 07:00 PM
JoeliusZ28's Avatar
ah... an A4.
I was wondering why you couldnt chirp first.
Old Feb 26, 2004 | 07:13 PM
cndctrdj's Avatar
how bad are DR's on a m6 if you only have a few bolt ons
Old Feb 26, 2004 | 07:31 PM
Cmr0z28's Avatar
I have 3.73s too......they chirped tonight when the air was a little cooler, but nothing worth mentioning. This afternoon it was about 75-80 degrees and sunny. Usually I can smoke the tires without even touching the brake, so these are a HUGE improvement. Personally, I wouldn't put drag radials on an M6 car. If you don't pop the clutch above 3k you should be okay though.
