My Air conditioner fan is acting crazy... within
Old Oct 3, 2003 | 09:46 PM
Schantin's Avatar
Question My Air conditioner fan is acting crazy... within
Simple dilemma. When I turn on the AC or heater and select the blower vents, the fan running the air doesn't come on. It DOES send the AC through the dash and floor heater ducts though.
IS this a fan problem....since air is coming from the heat vents? IF so, where is the fan? Is it in the dash? Is it easy to get to/ replace? Is it controlled by it's own fuse? Any help would be appreciated.... its a "strange" problem. Thanks in advance.
Schantin
1997 Camaro Z28
Old Oct 3, 2003 | 10:53 PM
Your problem description sounds kind of fuzzy. Do you hear the blower change speeds when you turn the blower speed ****? Is the problem that it only blows out on the floor and defrost vents and not the vents in the middle of the dash? If the latter, read here.
Old May 19, 2005 | 07:12 PM
30696bird's Avatar
Re: My Air conditioner fan is acting crazy... within
Hey shoebox, I have the later problem. Where is the fix located at on your site?
Old May 19, 2005 | 07:38 PM
Dave89IROC's Avatar
http://shbox.com/1/4th_gen_tech2.html#HVAC_vacuum
Magenta_Hearts
Mar 29, 2017 08:54 PM
MattFick
Feb 15, 2015 10:16 PM
ChrisFrez
Jan 25, 2015 08:06 AM
95chwagon
Jan 13, 2015 09:19 PM
Jul 4, 2005 05:00 PM
