My 94 z28 wouldnt start and when it finally did the CEL came on but now its off??
Old Jan 26, 2011 | 11:39 PM
DavinCity's Avatar
So my 94 camaro z28 has 80,xxx original miles.
Just got an oil change tranny fluid change, new opti, new plug wires, pump, fuel filter, idle control, etc.
So today i parked for a second, came back to the car and it wouldnt start (the idle stayed real low). After a few tries and stepping on the gas it started and the check engine light came on along with the fans... now i got home and let it sit for 2 hours and went outside (low and behold) it started right up with no check engine light????? CAN SOMEONE PLllleaseee help me this is so wierd.
Old Jan 26, 2011 | 11:53 PM
SkiBumDreams's Avatar
Re: My 94 z28 wouldnt start and when it finally did the CEL came on but now its off??
you need to have it scanned and find out what the code is. go to your local auto parts store (autozone, oreilly, advance, etc etc). Be sure to get the actual number code that comes up on the stores scanner. you need the actual numbers because lt1s have a specific code list that is more than likely not the same as the code list in the scanner.
Old Jan 26, 2011 | 11:54 PM
DavinCity's Avatar
the check engine light shut off so im so confused what i can doo now??
Old Jan 27, 2011 | 04:58 AM
Guest47904's Avatar
Guest
The code will be in memory for some time so you can still retrieve it. However, because the engine was idling so low. More than likely the code is due to a very low system voltage since the alternator was spinning so slowly. If the PCM goes into a "brown" condition, anything is possible.
Old Jan 27, 2011 | 06:34 AM
moparman's Avatar
Seeing as your car is OBDI, the chances that an auto parts store will be able to pull the code(s) are very slim.
Old Jan 27, 2011 | 06:46 AM
This statement ....."it wouldnt start (the idle stayed real low).".... is confusing.
If it didn't start, how could it be idling? Do you mean the started cranked the engine at a low speed?
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
squarehead
Nov 21, 2014 08:02 PM
