My 383 LT1 specs and pics
Well its been a LONG and quite expensive road but my 383 is pretty much done and is almost ready to raise (notice how i said raise) into my 1994 Trans AM
It is not a daily driver, it will be a weekend street/strip car. For now it will be run N/A and a healthy shot of n2o (100-200 range) and in the future I plan to get some larger CC heads, lower the comp down and throw on a super charger and a 150 shot. Current Static Compression is 10.885:1 and Dynamic Compression is 8.06:1 For anyone interested i'll start off with the specs:
Block: Originaly 1996 Caprice Police Car 5.7L LT1 w/ 86,000 miles, bored .030 over, decked line honed, hot tanked 1000 times, and converted to 4 bolt splayed main with 3 center program caps, Clevite "H" Series Bearrings all around, block also painted jet black.
Crank: Callies Dragon Slayer 3.75" Forged
Rods: Callies Compstar 5.7" Forged
Pistons: Custom JE -16cc, forged 2816 alloy w/ nitrous pins and Hell-Fire Rings.
Heads: LT1 Alluminum Casting ported by Total Engine Airflow, flowing 276in/248exh @ .600 lift, 2.00" intake valves and 1.56" Exhaust valves (Exhaust flowed with a pipe), bolted up with Cometic MLS .040 Head Gaskets.
Cam: Custom Bret Bauer 23x/24x
Valvetrain: Comp Cams Pro Mag 1.6 NSA RR, Comp Cams 'R' Lifters, PEP Springs, Titanium Locks, Comp Cams Chromemoly 7.2" push rods
Intake Manifold: Stock LT1 ported by Lloyd Elliot and enlarged to fit the Holly 58mm tb.
MISC
Canton Oil Pan
ATI Super Dampener
Holly 58mm TB
Aeromotive AFPR
Delphi 42lbs injectors
Chrome Valve Covers
Coyles Double Roller Timing Chain
Converting to Vented Opti
CSI Eletric WP
Deleting HVAC
Converting to new style Radiator hose design
Intake Manifold and Accessory bracket powder coated jet black
Etc etc etc etc.........
Now for a few pics:
http://www.webideas.net/94transam/38...r/dsc00002.jpg
http://www.webideas.net/94transam/38...r/dsc00003.jpg
http://www.webideas.net/94transam/38...r/dsc00006.jpg
http://www.webideas.net/94transam/38...r/dsc00007.jpg
Enjoy...Any questions?
It is not a daily driver, it will be a weekend street/strip car. For now it will be run N/A and a healthy shot of n2o (100-200 range) and in the future I plan to get some larger CC heads, lower the comp down and throw on a super charger and a 150 shot. Current Static Compression is 10.885:1 and Dynamic Compression is 8.06:1 For anyone interested i'll start off with the specs:Block: Originaly 1996 Caprice Police Car 5.7L LT1 w/ 86,000 miles, bored .030 over, decked line honed, hot tanked 1000 times, and converted to 4 bolt splayed main with 3 center program caps, Clevite "H" Series Bearrings all around, block also painted jet black.
MISC
Canton Oil Pan
ATI Super Dampener
Holly 58mm TB
Aeromotive AFPR
Chrome Valve Covers
CSI Eletric WP
Deleting HVAC
Now for a few pics:
Re: My 383 LT1 specs and pics
The exhaust was flowed with a pipe so that would inflate the numbers abit, i know not an insane amount but that in combonation with whatever port work TEA did net'd those numbers, they are TEA's "Stage 3" port job.
Timing cover plug i could have lived without, lol, Machine shop banged me for like $100 i think for that one. Total cost of machine work/assembaly alone came out to $5200. Hope it'll be worth it...
Nice setup, I like the Black intake as well. I too am going to get a ATI dampener and a canton oil pan for my setup. Do you mind PMing me where you got your Dampener and Oil Pan and at what cost. If its a sponsor you can go ahead and list the details, if not just PM me. Sounds like you have your fuel setup setup pretty good, I like the 42 injectors feeding this thing.
I imagine you will rev the motor in the 6500-6700 range give or take a little. If your a M6 with some Dyno Tuning (really depends on that) It could make as low as 425 or could make probably as high as 450. More than likely It will be in that ball park.
Wow! That looks really sweet! Too bad you cant see those chome rod bolts..
Damn, I expected more bling from the ghetto dawg, yo!
(did I say that right?
) How about we test that sucker out in the Z, I got a block in the garage you can use..
