Must i drain coolant from the block for cam install?
Old Mar 18, 2004 | 01:30 PM
Eds69s's Avatar
i'm working on tearing down my motor for a cam install right now. do i need to drain ALL the coolant, or just the radiator? when i did the waterpump last year, i don't remember draining the block.
Old Mar 18, 2004 | 01:37 PM
95BlackTA's Avatar
IF you dont, then when you take off your waterpump, all of the coolant will drain onto your opti...most likely ruining the opti.
Old Mar 18, 2004 | 01:39 PM
ibanez6rg's Avatar
For cam, no.
Old Mar 18, 2004 | 01:41 PM
bigde4u's Avatar
You can do it without draining your block, what i did is before i took of the w/p i covered my opti up real good so the coolant wouldn't get on it.
Old Mar 18, 2004 | 01:45 PM
Eds69s's Avatar
i just ordered a new opti today anyways. this one works fine but i figured since i'm in there i might as well replace it with 84k miles on it i couldn't find the 2nd block drain anyways... thanks guys, i'm sure i'll be back with more question later.
Old Mar 18, 2004 | 01:50 PM
ibanez6rg's Avatar
The passenger side block drain is the knock sensor.
Old Mar 18, 2004 | 01:55 PM
bigde4u's Avatar
yeah, what he said ^ just a tip though make sure you're not looking up at the knock sensor and are kind of out of the way when you get it all the way out. Coolant all in the face...don't ask me how i know.
Old Mar 18, 2004 | 01:58 PM
ibanez6rg's Avatar
Originally posted by bigde4u
yeah, what he said ^ just a tip thogh make sure you're not looking up at the knock sensor and are kind of out of the way when you get it all the way out. Coolant all in the face...don't ask me how i know.
I hate coolant... it's always a messy sight with me, no matter what I'm doing with it.
Old Mar 18, 2004 | 03:08 PM
GREGG 97Z's Avatar
That one came out pretty easy when I did mine, good luck getting the driver side one out. I snapped an extension trying to remove that one, never did get it out.
Old Mar 18, 2004 | 03:13 PM
Eds69s's Avatar
i'm not going to pull them out now, but just for future reference, where is the drivers side one?
Old Mar 18, 2004 | 03:18 PM
ibanez6rg's Avatar
Opposite side of the knock sensor, same location (I think). Right behind the k-member at the bottom of the block.
Old Mar 18, 2004 | 03:24 PM
GREGG 97Z's Avatar
Actually there is only one knock sensor, its on the passenger side. The one on the driver side is just a plug for draining the block. It's close to the motor mount and pretty hard to get at, I couldnt budge the thing.
Old Mar 18, 2004 | 05:23 PM
bigde4u's Avatar
Yeah i messed with it for awhile then said screw it!! It's a PITA to mess with.
Old Mar 18, 2004 | 06:47 PM
Drain plug
Old Mar 23, 2004 | 11:23 PM
cmillard's Avatar
I learned this from a friend (Quoc mentioned it I think) best way to drain coolant is a Wet vac.
You can remove the highest hose in the system and have the vacuum just pull all the coolant into the canister.
I recommend cleaning the vacuum bucket before of course, so you can re-use the coolant.
I've done it this way several times. Makes the draining so easy it's amazing.
Hope this helps,
Christian
Sandersen511
Jan 13, 2015 03:49 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
