Mulitple Spark Opti?
Old Jun 14, 2007 | 06:41 PM
Fei's Avatar
Fei
Should there be multiple sparks on a single plug? I pull #1 today since I'm having very bad idle issues and checked the plug. For each TDC of that Cylinder I get 4(maybe 5) sparks. Is this normal? Or do I have bad ICM?
Old Jun 14, 2007 | 08:54 PM
hotrod18_69's Avatar
You don't a MSD box hooked up do you?
Old Jun 14, 2007 | 11:38 PM
Fei's Avatar
Fei
Nope sure don't.
Old Jun 15, 2007 | 03:01 PM
Fei's Avatar
Fei
no one knows this?
Old Jun 15, 2007 | 03:16 PM
Never heard of such a thing on the stock system.
Old Jun 15, 2007 | 06:27 PM
Fei's Avatar
Fei
Odd. I think this maybe causing my miss and bad timing. I will try swapping some of the ign parts and see if that fixes it
Old Jun 15, 2007 | 07:04 PM
96ZCamaro's Avatar
How did you test it to make sure it was actualy sparking that # of times?
Old Jun 16, 2007 | 04:43 PM
Fei's Avatar
Fei
pull the plug and ground it and watch it fire
So changed the cap and rotor. This fixed the miss fire but it still sparks multiple times on each cylinder. A little odd but I'm ok with that. And I know for sure that there us no after market ignition on there seeing as I just pulled this setup out of my 94 and put it in my 92. I'm sure I would have found a box seeing as I rewired the whole car :-p
jwade88
Jun 14, 2015 09:38 PM
Bxlt1
18
May 27, 2015 05:00 PM
zxtce
May 7, 2015 08:53 PM
blkWidow
May 3, 2015 08:42 AM
grabbem88
Mar 18, 2015 01:25 PM
