Is MSD/other aftermarket coil worth it?
Re: Is MSD/other aftermarket coil worth it?
The best single-coil inductive-discharge ignition system for an LT1/LT4 is the STOCK '96 ignition system (this is an upgrade for the '92 to '95 LT1). The coil and igntion module (they should be used together) were designed to take the LT4 to the extended 6400 rpm limit.
In addition, it was designed with the best compromise for performance and longevity.
Tom Piper
Tom Piper
Tom Piper
Tom Piper
carguyshu
Jan 22, 2017 11:19 AM
