MSD opti CHEAP! $$$
Old Jul 14, 2008 | 01:02 PM
blue 79 Z/28's Avatar
MSD opti CHEAP! $$$
well, i am in the west coast of canada so its not exactly close for some of you. but i just picked up a new MSD opti II from our local parts distributor, Mopac auto supply for $400.00 cdn +tax, they are pretty huge in these parts, and distribute all over canada and the united states. if anyone is willing to order these the deal is there. i bought it because summit wanted $515.00 usd and this was an unbelievable deal. so just giving anyone a heads up that wants one.
http://www.mopacautosupply.com/main.html
even if you add shipping etc, you still come out way ahead. they have their main warehouse in Langley B.C. and 2 stores in alberta.
Old Jul 14, 2008 | 04:27 PM
Dadic 78's Avatar
I paid about the same for my MSD from Lordco (West coast Canadians Unite!!!) -- I've found Lordco to have pretty competitive pricing. Might have to check out Mopac for the online ordering tho.
Old Jul 14, 2008 | 05:50 PM
TobyZ28's Avatar
I've always ordered GM optis from cromer - I think it was around 315 or so for the 95 vented opti. I have it shipped to Pt Roberts then just pick it up and pay taxes across the border.
Aside from the short trip it works out a fair bit cheaper
Last edited by TobyZ28; Jul 14, 2008 at 06:28 PM. Reason: Clarified the type of opti I bought based on 96capricemgr's reply below :)
Old Jul 14, 2008 | 05:53 PM
96capricemgr's Avatar
They are talking about the vastly less reliable and more expensive MSD opti, not the better stock replacement.
Old Jul 14, 2008 | 06:57 PM
well having taken apart my oem opti, it had corroded from a fluid being in it, the optical wheel was warped and doing a dance, and the bearing was gone in the back. instead of replacing it with a stock one, the msd is warrantied, billet, and sealed better. optics aside. you get a msd rotor and cap, which is a 150 dollar mod to a stock one from the get go. the only negative is the timing adjuster, but if you set the timing on a pointer, it can be zeroed any time
Old Jul 14, 2008 | 07:38 PM
brianswimmer23's Avatar
well you forgot that the GM OEM opti is also warrantied it has either a year or 12000 mile whatever come s first! now BLUE79 i want to ask you how long was your opti on when you took it apart? i personally have had problems with MSD and will only stick with stock AC DELCO!!
Old Jul 14, 2008 | 09:04 PM
i dunno, i bought the engine from a car that was rearended, i ran it before removal and it was running rough and missing. it had 105k kms which is about 65k miles. most of the problems with the MSD is the rotor screws backing out and then self destructing the unit, taking off the cover and making sure the screws are loctited and tight before install. ive heard of a few having optic problems, but so does the oems, not really a plus or minus, msd warranties it. they do claim the optical is a higher end unit, and it does have a billet case and a beefy bearing good till 10k they claim. either way i paid 400 for mine new, not 515, so its not much over oem and it does have a better cap and rotor if nothing else. to each his own i guess
if my bearing wasnt blown out on my opti i might have tried to restore it, but i dont like the design at all. im used to gen 1's with distrubutors and i run all msd on my race car, and everyone else i know does too (mustangs and gm), and its all been flawless, so i stuck with them.
Old Jul 15, 2008 | 10:14 AM
mzgp5x's Avatar
Been thru 4 opti's. With MSD ignition parts, the stock type opti rotors have not lasted long. One failed in 2 weeks. Summit gave me a replacement which I promply voided warantee and inproved the deficient rotor design. But, I still have problems with carbon tracks and opti spark distribution performance with MSD high voltage. I only like to replace opti one time. Especially with an ATI blower in the way. I'm glad I moved the radiator.
HarleyZ28
Oct 5, 2015 06:23 AM
thenewkid
Apr 12, 2015 07:42 PM
nikolt1
Feb 27, 2015 09:10 PM
grgguy
17
Feb 23, 2015 07:57 PM
