MSD opti CHEAP! $$$
MSD opti CHEAP! $$$
well, i am in the west coast of canada so its not exactly close for some of you. but i just picked up a new MSD opti II from our local parts distributor, Mopac auto supply for $400.00 cdn +tax, they are pretty huge in these parts, and distribute all over canada and the united states. if anyone is willing to order these the deal is there. i bought it because summit wanted $515.00 usd and this was an unbelievable deal. so just giving anyone a heads up that wants one.
http://www.mopacautosupply.com/main.html
even if you add shipping etc, you still come out way ahead. they have their main warehouse in Langley B.C. and 2 stores in alberta.
I've always ordered GM optis from cromer - I think it was around 315 or so for the 95 vented opti. I have it shipped to Pt Roberts then just pick it up and pay taxes across the border.
Aside from the short trip it works out a fair bit cheaper
Last edited by TobyZ28; Jul 14, 2008 at 06:28 PM. Reason: Clarified the type of opti I bought based on 96capricemgr's reply below :)
well having taken apart my oem opti, it had corroded from a fluid being in it, the optical wheel was warped and doing a dance, and the bearing was gone in the back. instead of replacing it with a stock one, the msd is warrantied, billet, and sealed better. optics aside. you get a msd rotor and cap, which is a 150 dollar mod to a stock one from the get go. the only negative is the timing adjuster, but if you set the timing on a pointer, it can be zeroed any time
well you forgot that the GM OEM opti is also warrantied it has either a year or 12000 mile whatever come s first! now BLUE79 i want to ask you how long was your opti on when you took it apart? i personally have had problems with MSD and will only stick with stock AC DELCO!!
if my bearing wasnt blown out on my opti i might have tried to restore it, but i dont like the design at all. im used to gen 1's with distrubutors and i run all msd on my race car, and everyone else i know does too (mustangs and gm), and its all been flawless, so i stuck with them.
Been thru 4 opti's. With MSD ignition parts, the stock type opti rotors have not lasted long. One failed in 2 weeks. Summit gave me a replacement which I promply voided warantee and inproved the deficient rotor design. But, I still have problems with carbon tracks and opti spark distribution performance with MSD high voltage. I only like to replace opti one time. Especially with an ATI blower in the way. I'm glad I moved the radiator.
