MSD LT1 Distributor....
Old May 4, 2012 | 11:41 AM
GCEZ28's Avatar
Posted earlier about MSD distributor taking a crap and MSD telling me it was my ECU.
Here's an update...
Took everything apart again and opened up the distributor.
It was full of Mobil1......
Apparently the camshaft seal behind the distributor in the timing cover is bad.
Has this ever happened to anyone else?
So. I got exactly 2 month use out of this awesome distributor and now I get to buy another one!
Guess I'll do a timing chain also while it is apart again.
Old May 4, 2012 | 12:10 PM
Mystery Bird's Avatar
Re: MSD LT1 Distributor....
Call MSD, I think they can rebuild yours. Cheaper than buying a new one.
Old May 4, 2012 | 12:17 PM
96capricemgr's Avatar
There is no "camshaft seal", it is a seal for the opti drive. If that seal was bad and the opti not sealed I could see it filling the opti with oil.
As said you can pay MSD to rebuild it.
The MSD is not an upgrade from stock, the MSD cap and rotor are nice for adding a vent system to the "unvented" optis but the billet base is NOWHERE near the upgrade people expect it to be, if anything it is less reliable than stock.
A timing chain swap is MUCH deeper in than an opti swap and the timing chain is NOT a maintenance item. I can only guess you get that idea from the Neon in your sig.
Old May 4, 2012 | 01:00 PM
GCEZ28's Avatar
So... Where do you think it is coming from?? There is a seal in the timing cover (I called it a cam seal), would that not be the culprit?
Still attempting to talk to MSD... Waited for thirty minutes, got to "5th" in line (from 8th) and they hung up. Called back and was 15th! Still waiting......
Old May 4, 2012 | 01:22 PM
RamAir95TA's Avatar
The fact that MSD's customer service line has 15 people on hold at any given time should give you a strong indication on the quality of their products lately.
Old May 4, 2012 | 03:23 PM
The seal that is likely leaking is the opti drive seal in the timing cover, the waterpump drive seal failing could cause similar issues though. Both can be replaced with the timing cover on the engine.
Old May 5, 2012 | 11:28 AM
Jasonz28camaro's Avatar
MSD will do the rebuild with or without receipt for $125
Old May 6, 2012 | 09:05 PM
GCEZ28's Avatar
Anyone have anymore input on doing a timing set since I am this far? Just saw an article where they had a very visibly worn timing set from an LT1 with 125,000 miles. I have over 150,000 on mine.... They are not that expensive. And yeah 96capricemgr, not really interested in messing up any engine for lack of fixing something when I had the chance. Besides, my little Neon has been a trusty sidekick to me for some time now! Good thing cuz my poor Z28 has not been on the road much lately. I cant blame the MSD unit for my bad seal. I am calling them in the morning to get info/confirm above comments on getting it "rebuilt".
One last thought/?... Is there really that much oil up where that seal is? Wow. there was kinda a lot of it in the distributor.
Old May 6, 2012 | 09:36 PM
Get the heavy duty timing set. I think it's the one they use on the lt4 motors?
Old May 6, 2012 | 10:04 PM
matLT1's Avatar
Been through the MSD opti and what he says is true. Not impressed and it is definitely not worth the $$$.
Old May 6, 2012 | 11:01 PM
The original poster has a 94. The LT4 Extreme Duty set only works with the vented Opti, so in addition to the exorbitant price for the LT4 set, he would need a vented Opti, a new timing cover, a new short Opti harness, a vacuum/vent harness, and a new camshaft. And the ED LT4 set is total overkill unless he's running a solid roller cam with huge valve spring pressures.
Old Jul 12, 2020 | 05:17 PM
bizness88's Avatar
I sent one to get rebuilt at MSD. How long did your rebuilt unit last?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
nikolt1
Feb 27, 2015 09:10 PM
thenewkid
Nov 27, 2014 09:41 AM
