MSD Install in progress..
Old Nov 11, 2006 | 08:31 PM
ZFan88's Avatar
Did anyone have a clearance problem with this for the install?..
Old Nov 11, 2006 | 09:28 PM
There should be a cast line on the hub that should be at 12 o'clock to allow the opti to just slide by.
Old Nov 11, 2006 | 09:41 PM
ZFan88's Avatar
What? lol
I had it positioned so I could pull the stock opti out with a litte adjusting.
Old Nov 11, 2006 | 09:48 PM
FryedClutch's Avatar
yeah from the pic it looks like its in its proper position some times you gotta just be slick with it lol
yah gotta kinda slide it down at a slight angle and it should go right in
Old Nov 11, 2006 | 09:50 PM
ZFan88's Avatar
Ok, I think I got it. I'm out of daylight now so will finish up in the morning. I'll just angle it in and then worry about lining it up, should be fairly simple. I'm just glad I didn't have to remove the fans or use a puller
Old Nov 11, 2006 | 09:52 PM
yeah its really easy once you get the hang of it sometimes ya just gotta mess around with the angle a bit
but it sounds like you got it
Old Nov 11, 2006 | 09:53 PM
ZFan88's Avatar
Cool, thanks. It's a pretty simple job for anyone who is afraid to do it. This is my first time, and everything has gone smooth...but I didn't realize how much coolant is actually in there lol..and on the floor now
Old Nov 11, 2006 | 11:06 PM
Originally Posted by ZFan88
What? lol
What do you mean what?
If you had it in the right positon to take the old opti off, it should be in the right position to put the new one back on. Though, IMO, from the looks of your pic, it's not in the right position. I don't see the mark showing on the hub. The spokes of the hub are not symmetrical and there is more room between two of the spokes than the other ones. The mark is between those two spokes. Your pulley arrow also lines up with this mark.
Old Nov 11, 2006 | 11:14 PM
ZFan88's Avatar
Ah, that makes sense. Should make for an easy install then in the morning. Thanks for the tip, your website's very helpful by the way
Old Nov 11, 2006 | 11:35 PM
playa7970's Avatar
i know what your mean about the coolant lol when i first did it i was like god **** thats alot youll get through it though not bad at all you feel good once its done and finished
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
