msd ignition question
Old Oct 20, 2004 | 08:13 PM
george0924's Avatar
i saw a msd digital 6 plus ignition 4 sale will that work on my 94 z28 and is that any good? what other mods should i make along with it if it will work?
Old Oct 20, 2004 | 08:33 PM
IrocSS85's Avatar
Re: msd ignition question
I dont see why not. Ive never seen it done before, but it should function just like a 6a box. exc. the digi. 6 is way better w/all the adj. features. why not right an email to msd tech support?
other mods should be coil and good wires/plugs.
Old Oct 20, 2004 | 09:07 PM
96capricemgr's Avatar
Not worth looking at aftermarket ignition stuff unless you have a power adder.
Old Oct 20, 2004 | 09:17 PM
IrocSS85's Avatar
I disagree. unless your car is bone stock. the aftarmarket ign. box will help increase combustion efficiency giving you a smoother running engine, rev. limiter that you can change, better gas mileage, and an even smoother running eng. if you have some mods like a cam. IMHO anyways. maybe the dig. 6 is overkill w/no power adder cause of all the features, but an msd 6a or crane would be worth it.
chris
Old Oct 20, 2004 | 09:31 PM
Max 93's Avatar
yes, it will work. I am using on on my 93. Just buy the wire harness so that it is plug n play
Old Oct 20, 2004 | 09:55 PM
george0924's Avatar
I was imterested cuz it was only like $80 i felt like if it took a little doing it would still be a steal...
thankyou guys for the imput!
Old Oct 20, 2004 | 10:10 PM
EDS Z28's Avatar
Thumbs up Re: msd ignition question
I've used that ignition box for a few years now. It has been awesome. MSD is the best!
I have it mounted on the front end of the car on the passenger side attached to the frame. Right where the horns are. I'm using it with their blaster replacement coil. I was thinking about using the bigger HVC coil, but the ignition works excellent the way it is now.
Old Oct 21, 2004 | 03:55 PM
meangrn94ta's Avatar
i just bought one of the msd digital 6 plus's for my car and i have a couple friends here localy that have them as well and they work great. just make sure your get the harness for your car.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
CARGASM
Sep 4, 2002 11:17 AM
smackkk
Jul 22, 2002 05:17 PM
