MSD Ignition mounting
Old Apr 28, 2005 | 06:23 PM
BLinindoll's Avatar
Where is a good spot to put it? I can't find any room for it anywhere. I like the idea of having it inside the car, but I don't want to have to extend the wires TOO long. The engine bay would be OK, but I can't find any room!
Old Apr 28, 2005 | 08:30 PM
ABA383's Avatar
Re: MSD Ignition mounting
I mounted mine on the driver's side inner fenderwell just behind the fuse holder. You have to remove the fuel line clip that just pops put of the hole in the fenderwell. You can only use two mounting screws to hold the MSD box to the flat surface of the fenderwell, but its secured fine. I zip-tied my fuel lines to my brake lines for the line lock to keep them out of the way. No need to extend anything and it has worked fine for 3 years. If you want to be srealth, paint it black first.
--Alan
Old Apr 28, 2005 | 10:28 PM
BLinindoll's Avatar
I saw that spot but wasn't sure if it was going to fit. I didn't really want to move the fuel lines though. Kinda like the way they are. But, if I gotta put it there, I gotta put it there. Before I do it though, any other good spots guys?
Old Apr 28, 2005 | 10:52 PM
romoranger's Avatar
my battery is gone and it is there, but i am goignto take out the window washer fluid bottle and move it there so i can put someother stuff where it is right now i think
RUENUF
Mar 13, 2016 03:39 PM
CARGASM
Sep 4, 2002 11:17 AM
DirtyredT/A
Jul 29, 2002 11:27 PM
smackkk
Jul 22, 2002 05:17 PM
