msd ignition box
Old Aug 19, 2006 | 05:10 PM
fbodyboy's Avatar
msd ignition box
Is anyone running msd's 6a ignition box? If so what do you think about it?
Old Aug 19, 2006 | 05:36 PM
speed_demon24's Avatar
Re: msd ignition box
Why do you want an ignition box, just to have one, or nitrous, ect?? I'm happy with my mallory 685 for nitrous, it has a built in window switch, pulls timing, rev limiter, 2 stage, ect, and theres no dials, its an LED screen for the adjustments.
Old Aug 19, 2006 | 05:50 PM
camzaro28's Avatar
i ran mine for a year or so. if anything i thought it smoothed out my idle. now i am running the mallory due to nitrous. if u can get a used one for cheap id say go for it. hopefully someone else can chime in answer your ? though
Old Aug 20, 2006 | 01:18 AM
streetwarrior96's Avatar
works like a charm on mine. Used for NO2 with MSD 2 Step along with MSD Digital Multi-Retard
Old Aug 20, 2006 | 03:31 AM
IdahoLT1's Avatar
mine went out a couple weeks ago (car wouldnt turn over). So i disconnected it and the box is still in there. It was on the car when i bought it so i dont know how long its been there.
Old Aug 20, 2006 | 11:50 PM
fbodyboy's Avatar
thanks for your opinions. I was thinking of getting one because i was planning on nitrous and i'm about to have my car dynotuned soon and wanted to upgrade the ignition and fuel systems before i did. I also wanted to get the car to run as smoothly since it is my daily driver.i have to msd 8.5 wires and was going to put ngk plugs and the msd coil on along with the ignition box. i'll probably pass on the box but what do you guys think about the msd coil?
Old Aug 21, 2006 | 06:33 AM
camzaro28's Avatar
im running one, that was the 2nd mod i did actually. its cheap and better then stock. go for it, imo.
and if u are going to run nitrous u need something to retard the timing and u also need a window switch. mallory 685
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
detroit1994z28
May 14, 2015 12:09 AM
Drtryder
Apr 22, 2015 04:17 PM
smackkk
Jul 22, 2002 05:17 PM
