MSD ignition
Old Jul 13, 2003 | 09:50 AM
19-CamaroZ28-97's Avatar
MSD ignition
I was thinking about putting a MSD ignition (I'm not set on the MSD brand, thats just the one I could think of for an example) on my bone stock 1996 SS. I've got a couple questions for you guys who know about this stuff:
1 - what system would be ideal for me (daily driver)
2 - how much is it going to help the performance of my car
3 - how hard is it to install (is there "plug and play" convience?)
4 - what would be some good componets to install to compliment the system
Old Jul 13, 2003 | 11:45 AM
cals400ex's Avatar
as far as performance, i doubt you notice anything. however, msd says you get: quick starts and smooth idle, instant throttle response, improved high rpm pull, and reduced spark plug fouling. the basic model is for a relatively mild setup. this is the 6200. they also make some higher models that have a rev limiter setting and others offer adjustable amounts of retard for boost pressure. they do make a wiring harness that makes it easier to install. however, my friend has one on his 87 iroc 350 and i think there was only three wires coming off the msd box. i don't know if you need any other components to go with one of these boxes or not. i would just say make sure your plugs, wires, coil, and opti is in good condition. what part of kentucky are you from? there is a msd dealer in Louisville, bowling green, ashland, lexington, and pikeville in kentucky. if you are by any of these places, let me know and i will give you their # and address and that way you can call them or stop by and let them answer any other questions.
Old Jul 13, 2003 | 12:40 PM
I'm right outside of Bowling Green, it would be great if you could tell me the dealer # and address! Thanks for the helpful information
Old Jul 13, 2003 | 06:47 PM
cals400ex's Avatar
the dealer in bowling green is called Scotty's Speed & Custom
2418 Scottsville Road
Bowling Green, KY 42104
the # is 270-842-0646
good luck
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
