MSD digital window switch and deltec???
Old Jun 2, 2005 | 08:20 PM
hambone3441's Avatar
Trying to get some info on how to set up the window switch with the deltec system (ie what wire to tap off of) and all. Talked to Maldo at elitesparkplugs.com and he said that it probably wouldnt work, so I got looking at the instructions more and it will work with a variety of different ignitions so I thought I would poll the crowd here and see if anyone has done this setup or has any insight into it. Thanks in advance for any input.
Rob
Here are the instructions for it and it will work with an ls1 style ignition so that got me thinking.
http://www.msdignition.com/pdf/8969_frm25515.pdf
Old Jun 3, 2005 | 05:32 AM
Re: MSD digital window switch and deltec???
ttt
Old Jun 3, 2005 | 06:53 PM
No one has any info on this????
Old Jun 3, 2005 | 09:10 PM
80TA's Avatar
I just ordered one of these and was planning on delteq in near future.
I would think it should work .Hope someone comes up with a way for it to.
Old Jun 6, 2005 | 12:46 AM
1982z28with18s's Avatar
Well, bad news for you, your only option really is to get a msd dis-4(~$400), and if you get that you also need to get the interface adapters for the northstar coils(another ~$105). Then I believe you need to order a window switch for the msd box, but I'm not positive if the msd box has a built in window switch or not. Not cheap to do.
Old Jun 6, 2005 | 06:06 AM
I dont understand, if it can work on an ls1 motor why not with the deltec setup on a lt1???
Rob
Old Jun 6, 2005 | 06:28 AM
Just what Pete from delteq told me, maybe you should give him a call or email him.
MichiganSkip
Aug 31, 2002 08:52 PM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Redbird
Aug 2, 2002 06:50 PM
