MSD Coil a good mod??
Old May 25, 2004 | 04:45 PM
white97z/28's Avatar
I was thinking about getting one, since they are pretty cheap. What are the pro's and cons of one. Seems like before i have read somewhere on this board or others that they go bad or something after 2 or 3 months of use. Is this true or just bs. Is it worth getting?
Old May 25, 2004 | 05:13 PM
z28marine's Avatar
heard the stock is good enough...i imagine if your running a larger motor then u might need it, but for your average bolt on lt1 the stocker should be good enough
Old May 25, 2004 | 05:14 PM
If your 97 coil is working now, it won't likely be of much benefit to get another coil. The 96-97 stock coils are pretty good ones.
Old May 26, 2004 | 03:08 AM
HungryT/A's Avatar
I have a Blaster III High Vibration coil mounted on my left shock tower. It's probably an overkill for my car, wasn't a plug'n'play mod either, but works flawlessly for 3 years now...
nikolt1
Feb 27, 2015 09:10 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
thenewkid
Nov 27, 2014 09:41 AM
