MSD Cap/Rotor
Old Apr 3, 2007 | 10:46 AM
Handyman's Avatar
Thumbs down MSD Cap/Rotor
Well, after only 1 racing season on the New Msd Cap and Rotor it broke Friday night at the track.
Huge Back fire and the car shut down. Exactly at the end of the track.The little screws broke off and sent the rotor flying. These were lock tight in and silocone over the heads last year. No other damage to the car. I ran on the stock opti set up untill I thought I was upgrading. My opinion is it's not worth it. I replaced it with a stock unit from Dal. Wanted to let you guy's know.
Old Apr 3, 2007 | 10:59 AM
wrd1972's Avatar
The screws actually broke in half. Wow aint heard that before. Sounds like crappy screws rather than a problem with the rotor. Those silver ones dont appear to be the GM torx headed ones which are the ones I would have used.
Could you have overtightened them and weakened them?
Old Apr 3, 2007 | 11:08 AM
TobyZ28's Avatar
Although its hard to tell from the picture, the screws appear to look like cheapie screws... I'm no engineer but they do remind me of something I'd use to screw in a computer case...
Old Apr 3, 2007 | 11:18 AM
Handyman's Avatar
After several calls to MSD they said the screws have been updated to allen head in the last few batches Tech support said there were some problems with the first few batches.They also offered to send me a new cap/rotor under warranty I pay shipping both ways and it would take 10 to 14 days. I'am going to pass on the offer.
Old Apr 3, 2007 | 10:06 PM
quickSS's Avatar
Hey John,
Were you on the nitrous when this happened? No matter if you were or were not but it seems like those screws were damaged by something.
Where did I read that your oil pump drive shaft also broke? I don't see it here but did I read that on impSSforum.com?
I would think the motor went into "rattle" mode and caused those items to break., well, even if the opti rotor did come off I would still suspect my engine had some other problem. Reason being, every single time somethin g like that happens to one of my motors, (oil pump drive shaft breaking, rocker slipping off pushrod, head gasket blowing), it was caused by detonation----rattling the motor).
Karl
Old Apr 3, 2007 | 10:43 PM
sbs's Avatar
sbs
Even if you're not going to use it, you could sell it.
Old Apr 4, 2007 | 02:19 AM
TobyZ28's Avatar
I'll pay for your shipping there and back and then to me and maybe a few for your time to arrange it all?
Old Apr 4, 2007 | 12:06 PM
Ken95Z28's Avatar
At least use the rotor, the stock ones can come apart. Had my stock one flew apart, the rotor was still attached but the brass blade was off. I since then modified it so it won't happen again.
Rotor Fix
Sounds like just upgrade the screws and you should be fine.
Old Apr 4, 2007 | 05:18 PM
LTgun_94's Avatar
Well my MSD opti was crap too so dont feel bad..except mine was the whole unit and cost me alot downtime and money! Im sending mine back tomorrow for them to test it tomorrow. It sucks that you cant get anything for your money anymore...MSD
Old Apr 4, 2007 | 10:30 PM
quicksilver97ta's Avatar
I think I got one the first ones, it had unbelievably bad fastners. The screws for the rotor were shorter than stock but the base of the rotor was actually thicker. The heads of the screws were tiny and it came with washers but using them would make the thread reach even less, didn't matter though the washers were too wide to fit in the recess in the rotor. Complete junk.
I used all the original opti faster except for the extra one on the cap.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
