MSD 6A or 6AL???
Old Dec 26, 2003 | 09:03 AM
caboZ's Avatar
MSD 6A or 6AL???
Ok, I'm going out today to get either a MSD 6A or 6AL ignition box. My question is, which one should I get? I know the 6AL has the rev limiter on it but isn't that controlled by the PCM??...If so, then wouldn't I be just as well getting the 6A? Just wondering...........don't wanna go get the 6A then find out I need the 6AL.
Thanks for your input!!!
Old Dec 26, 2003 | 09:06 AM
Pasky's Avatar
Believe I read another post on the forum saying the 6AL isn't worth the money since the PCM does control the rev limiter. Go with the 6A. BTW, I could be wrong.
Old Dec 26, 2003 | 09:12 AM
1994CamaroZ28's Avatar
if you ever plan on running nitrous id get a 6al, the stock revlimiter and nitrous does not mix at all.
Old Dec 26, 2003 | 09:16 AM
caboZ's Avatar
Thanks for the info so far.............I'm not planning on running nitrous................at least not for quite a while ............ ............if ever.
Old Dec 26, 2003 | 08:19 PM
OBE1 95Z28's Avatar
The stock rev limiter cuts fuel to the cylinders to limit the revs whereas the 6AL cuts ignition. I prefer to cut ignition as cutting fuel can cause a lean condition that isn't healthy for the motor.
Old Dec 26, 2003 | 08:25 PM
engineermike's Avatar
I say get neither one. They don't add any power unless there's something wrong with your stock ignition. I've had several fail over the years, sometimes having to bypass them at night in the cold.
Why would anybody want one, anyway?
Mike
Old Dec 26, 2003 | 08:31 PM
OBE1 95Z28's Avatar
Below 3K rpm the MSD provides multiple sparks that should provide a more complete burn. This can provide cleaner running (helpful at smog time) and potentially better fuel economy. Above 3K rpm, they provide one hotter spark. I run a blower so it's manditory as a blower can actually blow out the spark. For $160 I think they're a good deal. Finding a good mounting place is the biggest challenge!
Old Dec 26, 2003 | 09:02 PM
Aaaaahhhh. . . Smog time. . . We don't have that here in Louisiana.
Like you, OBE1, I am forced to run one because the increased cylinder pressure from my 14 psi T-trim was putting out the spark. It won't run at full throttle over 4000 rpm without it.
But, as I said, if I didn't absolutely need one to fix some problem, I wouldn't have one.
Mike
Old Dec 26, 2003 | 09:17 PM
jonaddis84's Avatar
Why not the Digital 6, little more money, but has timing retard built in and a two stage rev limiter i think, maybe not two, but it at least has an electronic rev limiter instead of fuel.
Old Dec 27, 2003 | 01:00 AM
Z28ROC's Avatar
As previously stated, It's probably not necessary to get an ignition box. Unless you're spraying or boosting. But hey it certainly can't hurt either. So since you don't plan to spray, get the 6A.
Old Jan 6, 2004 | 03:03 PM
smokerZ28's Avatar
I just recently got my MSD 6A box from summit. Don't really need it but im upgrading my ignition and swaping heads/cam, more compression and figured it wouldn't hurt.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
