MRG-5716... ok for alum heads
Old Aug 20, 2004 | 12:42 PM
LT4orbust's Avatar
MRG-5716
Head Gasket, Ultra Seal, Composite Type, 4.100 in. Bore/.026 in.Thick, Chevy Small Block LT-1, Pair
are these head gaskets ok to use on aluminum heads, .026 in.Thick,the ad says they're for steel heads but i believe i've heard they can be used with aluminum heads
Old Aug 20, 2004 | 03:28 PM
kmook's Avatar
Advanced Tech Moderator
Re: MRG-5716... ok for alum heads
Yes.
I just ordered a couple sets today myself.
Oh and one order of them includes both gaskets (for like $35).
Old Aug 20, 2004 | 03:37 PM
chevyguy3's Avatar
i have been using those gaskets on several combos for 4 years now, they work good and are coated for aluminum heads
Old Oct 8, 2004 | 08:53 AM
Jeff95TA's Avatar
Are the coolant hole sizes the same as the stock gaskets? Anyone have a set they can compare?
If not, do you think they could be ground larger to match the stock gasket?
Roadie
Feb 16, 2015 10:34 AM
ddr698
Jan 9, 2015 10:05 AM
NewsBot
Dec 28, 2014 06:20 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Don 97 SS
Jul 11, 2005 08:50 AM
