Mr. Gasket 5716 headgasket packaging
Old Dec 3, 2007 | 05:50 PM
marshall93z's Avatar
I bought a set from Autozone. Got home and they slid right out of the package. No problems whatsoever, so maybe they finally fixed the way they packaged them before.
I read a lot of people say a while back that they were shrink wrapped. Mine weren't. Just two gaskets kinda loosely packaged inside a plastic bag attached to the cardboard pack.
Old Dec 3, 2007 | 05:53 PM
wrd1972's Avatar
It appears they have resolved the problem.
Old Dec 4, 2007 | 11:07 AM
I don't know what the old packaging looked like, but here is what mine is like.
Old Dec 10, 2007 | 12:56 PM
1SlowFormula's Avatar
much better design then they had before, where you had to buy 2 packs just to get 2 good gaskets...
Old Dec 10, 2007 | 03:13 PM
NightTrain66's Avatar
I will strat recommending these again.
The old packaging was the reason I stopped.
Old Dec 10, 2007 | 03:47 PM
Javier97Z28's Avatar
Moderator
I still question the quality of that gasket based on "feel"... I could be 100% wrong but I just didn't get that "quality" feel of it like I do with the FelPro or OEM.
Old Dec 10, 2007 | 05:17 PM
MeanGreen97Z's Avatar
The 5716 is .029?
Old Dec 10, 2007 | 05:24 PM
mdacton's Avatar
after using cometics I won't use anything else again
Old Dec 10, 2007 | 05:57 PM
speed_demon24's Avatar
I won't run anything from mr gasket again for the simple fact that they couldn't even get something as simple as packaging a gasket right.
Old Dec 10, 2007 | 06:31 PM
The cometics are at a good price too. Can't beat that for sure!
Old Dec 10, 2007 | 07:22 PM
IrocSS85's Avatar
well, are these .029" and how much are these? need some cheap ones for a stock rebuild Im doin.
Old Dec 10, 2007 | 07:52 PM
quickSS's Avatar
These are .026" thick and I see Summit has them at $70 bucks for a pair.
They may come individually too for about $37 each.
Also, the Mahle/Clevite Victor Reinz LT1 head gasket is about $20 bucks each (same .026" thick as the Mr. Gasket). If you can find that gasket at a local parts store it may be worth looking at.
Karl
Old Dec 11, 2007 | 10:41 AM
Which side goes up on these things?
Old Dec 11, 2007 | 11:06 AM
Called Mr. Gasket and they said it doesn't matter. I don't buy that because the sides are definitely different.
Old Dec 11, 2007 | 11:35 AM
And this was after they told me I had the wrong gasket.
