MPG problem
Old Apr 20, 2004 | 11:05 PM
78sixbanger's Avatar
MPG problem
Ok, im gettin an average of about 10 mpg, with mostly highway miles. My fuel filter was just changed, cat was put on a little over a year ago. new ngk tr55 plugs ad msd 8.5 superconductor wires, both installed about 4 months ago. Exhaust wise im runnin eddlebrock shorties, to 3" y, to eddlebrock 3" catback witha 3" dump. Anyone have any suggestions? Its killing my pocket.
Old Apr 21, 2004 | 05:07 AM
slopokrodrigez's Avatar
Sounds like you either need an injector cleaning or a sensor tune up.
Check to see if the vac line to the FPR is wet. If so change the FPR cause it's dumping fuel into the intake.
If that's ok, check the fuel pressure when the engine is turned off. See how fast it goes down.
Since your using a cotton air filter, try cleaning the MAF. Many people put too much oil on the filter and it contaminates the MAF.
The last thing is to check the sensors to see how they are acting. Like the MAP and the O2's.
Old Apr 21, 2004 | 12:00 PM
what do u mean by a sensor tune up?
Old Apr 21, 2004 | 12:08 PM
Scream And Fly's Avatar
Things like oxygen sensors start to become less effective after about 50K miles. I think he means you should make sure all sensors on your car are working as they should. Bad oxygen sensors will most certainly be one cause for poor fuel economy.
Greg
Old Apr 21, 2004 | 12:09 PM
Wouldnt o2 sensors throw the ses light?
Old Apr 21, 2004 | 12:12 PM
Not always. Over time, the oxygen sensors will become coated with carbon and other deposits, which will cause them to give wrong readings to the ECM, however, that situation will not throw a light.
Greg
Old Apr 21, 2004 | 12:17 PM
ok, i thik im gonna change them, thanks
Old Apr 21, 2004 | 12:27 PM
wiked95ta's Avatar
Can a carb and choke cleaner be used to clean the MAF?
Old Apr 21, 2004 | 12:47 PM
one more question, where are the o2 sensors located
Old Apr 21, 2004 | 12:54 PM
On your car they are located at the bottom of each exhaust manifold.
Greg
Old Apr 21, 2004 | 01:00 PM
LSUxBlake's Avatar
No, I wouldnt use that. I use electric parts cleaner (Autozone) and you dont even have to touch the wires on it. You just spray it and you see the dirt coming off of it. Some people use Q tips, but be VERY careful.
Old Apr 21, 2004 | 01:02 PM
turbo_Z's Avatar
you probably have an exhaust leak with the addition of the headers. dont go out and spend money on sensor you arent positive are bad... that is waste of money. instead do some investigating around the collectors and header flanges for signs of carbon deposits. if the leak is bad enough you could even hear it making a "putt-putt-putt-putt" sound in sync with the exhaust pulses.
Old Apr 22, 2004 | 10:49 PM
anyone have a pic of the location of the o2 sensors and the fuel pressure regulator
Old Apr 23, 2004 | 01:44 AM
Lower's Avatar
Both your picture requests can be found here:
http://shbox.com/1/4th_gen_tech1.html
Credit to Shoebox.
Also: I'd have to agree with turbo_Z -don't spend money on parts that aren't confirmed bad. Ask me and my *still* 10 MPG car how I know this doesn't work.
Old Apr 23, 2004 | 08:52 AM
Well, o2 sensors arent that bad in price so i figure i'll just pick two of them up, then i figure I'll upgrade my injectors and throuw on an ajustable fpr. Oh and ts not an exhust leak, the headers have been on the car for a couple years, the problem just started like 2 months ago and keeps gettin worse.
cmsmith
Apr 11, 2015 09:37 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
canbaufo
Feb 24, 2015 10:27 AM
grgguy
17
Feb 23, 2015 07:57 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
