Mounting PBR's on a 96
Old Dec 26, 2003 | 11:06 PM
JOE96Z28SS's Avatar
I have a set of 98Z28 Calipers ONLY what other hardware do I need to make them Work on my 96 does anyone make kits or do I need the two arms off a 98
Old Dec 27, 2003 | 02:00 AM
predator's Avatar
so basically you are doing the ls1 brake install
1. calipers (you have)
2. ls1 steering knuckles
3. you can use youre hubs they are the same
4. you need to use the lt1 lines but! you have to use the ls1 calipers banjo bolt. also make sure to bend the braket on the body where the lines meet to make them a litttle longer so you dont bust a line
and that should do it for ya
also make sure to install the calipers with the bleeder screw facing up. the calipers ARE! rversable
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
