Mounting mallory 685
Old Apr 17, 2005 | 12:18 PM
wicked_95z's Avatar
I want to mount it on the firewall behind the pcm where my a/c used to be but I'm worried that its too close to the longtubes. Will that be okay?
Old Apr 17, 2005 | 02:22 PM
Loadre's Avatar
Re: Mounting mallory 685
Should be fine. Might wanna try and use some heat shield or something. They're pretty good about replacing stuff if it goes out anyway. Mine's in the glovebox for what it's worth.
Old Apr 17, 2005 | 03:46 PM
Makaveli's Avatar
how hard was it to extend the wiring harness into the car's glovebox compartment? i was thinking of doing this and never got around to seeing whats involved
Old Apr 17, 2005 | 08:48 PM
Loadre's Avatar
Two bolts and the PCM comes out. There's a grommet on the firewall behind it. Extend the wires and route through the grommet. Voila.
Old Apr 17, 2005 | 09:06 PM
OBE1 95Z28's Avatar
Electronics and extreme heat don't mix well; I'd find another location.
Old Apr 17, 2005 | 09:12 PM
lamb110's Avatar
Mines mounted under my Passenger seat, move the seat all the way up and you can access it very easily. Its a really clean set up.
Old Apr 17, 2005 | 09:37 PM
RacerTim's Avatar
Mines in the center console, very easy access. I didn't feel like having to reach across the car to the glove box to change stuff on it.
Old Aug 12, 2005 | 09:18 PM
limige's Avatar
keepin' ideas flowing, i'm relocating my battery inside the car and mounting the box on the frame rail where the battery was.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 22, 2015 02:31 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
Daluchman1974
Sep 11, 2015 06:12 AM
