motor mounts
Old May 17, 2008 | 04:40 PM
  #31
ssbowtie1's Avatar
Originally Posted by caldercay
You know what - I did have to "grind" the corner of the mount, but I cant
remember if it was because of that bolt. Not that I ground it, but I used a
very sharp knife to whittle away the clearance that I needed.
I did the "grinding" while the mount was in place, because I think that
the upper "u-shaped mount" (that is bolted to the block) was hitting on
the urethane as I slowly lowered the engine down to mate with the poly.
I have somewhere to run right now, but I can take photos of the final
install a bit later, if it's helpful.
Thanks alot. I just took a razor and clearanced some material from the two corners that the bolts need to go through.
Originally Posted by kgkern01
I've already got the Hooker LT's installed, just didn't know how much they would be in the way of swapping mounts and how long to swap the mounts out.
I have jet hot headers which are very similar to hooker headers. I just finished replacing my pass side motor mount. Its a bit cramped but definitely doable. As for the drivers side, I'll have to get back to you on that tomorrow when I try that side.
Old May 20, 2008 | 02:17 PM
  #32
ssbowtie1's Avatar
Just a quick update:
I just finished doing the driver's side motor mount. Do not over tighten the new bolts that hold the camshell in place, as they will shear off
I found the driver's side to be a bit more of a pain than the pass side. Less clearance with my jet hot headers. Also, I had to loosen the bolts holding the other motor mount bracket on the k-member, and moved it around some to get the through bolt back in.
All in all, the install took a couple hours. Not as rough as some people make it out to be
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
