motor mounts???
Old Dec 21, 2005 | 11:32 PM
slp97camaro's Avatar
Question motor mounts???
does anyone know the easiest way to change the motor mounts in a 97 ss?? im thinking i can just lift the engine up a little and get to them? but i have no clue...anything would be helpful..thanks
Old Dec 21, 2005 | 11:36 PM
RICEFEDZ28's Avatar
Re: motor mounts???
It won't be very easy. Id undo the long bolt going through the mounts, then undo the mout from the k member, remove the bottom part of the mount the it will be easier to remove the top portian attached to the block. Good luck and have fun.
Old Dec 21, 2005 | 11:48 PM
Re: motor mounts???
lol yeah...im sure ill have fun..thanks for the advice tho
Old Dec 22, 2005 | 08:34 PM
Jeff H's Avatar
Re: motor mounts???
Do you have the exhaust manifolds out? If not, the passenger side will be really hard unless you lift the engine a lot. I took the long bolt out on the driver's side and slid the lower mount up and out but that will only work if you have the steering shaft disconnected. On the passenger side it looked like the only way was to unbolt both parts of the motor mount and slide the whole thing back to get it out. But I'm in the middle of a header swap and didn't have the passenger side in yet. It looks like it would be real hard to do the passenger side if the exhaust was still on the car.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
