Mr.Gasket header gaskets
Old Dec 19, 2005 | 08:32 PM
69z-28's Avatar
im buying pretty much all used exhaust components, including headers and y-pipe and i really dont have much money but im trying to not be so cheap as to screw myself in the long run. anyone know anything about the LT1 header gaskets from Mr.Gasket? Jegs has them for about 20 bucks.
any info or anything is greatly appreciated. thanks
http://www.jegs.com/webapp/wcs/store...ctDisplayPopup
Old Dec 19, 2005 | 08:36 PM
UtOhCop's Avatar
Re: Mr.Gasket header gaskets
Get the Mr. Gasket copper header gaskets. BEST you can buy
Old Dec 19, 2005 | 08:39 PM
FastZinTennessee's Avatar
I use Fel Pro gaskets that I've bought at Autozone. Probably be about the same price once you figure shipping in from Jeg's and I"ve never had a problem with mine at all. You could smear a little RTV around the ports for some added security if you're worried.
Old Dec 19, 2005 | 09:17 PM
69z-28's Avatar
shipping from jegs is free, either way is it worth it to spend about the extra 10 dollars on the copper? like i said im trying to be very conservative yet not stupid...
Old Dec 19, 2005 | 10:28 PM
walt355's Avatar
Ive got them and reused them about 3 or 4 times. Mine dont seal worth a **** though.
Old Dec 20, 2005 | 12:07 AM
LT1 POWR's Avatar
I tried those Mr Gasket Copper gaskets when i first installed my headers and they didn't seal at all. I switch to felpro's a few weeks ago and everything look good so far.
Old Dec 20, 2005 | 12:09 AM
Deenasty's Avatar
Use the felpro 1406, and spray copper gasket on them, on both sides. Allow about 1 min to dry, and install. They will not leak at all..
Old Dec 20, 2005 | 12:55 AM
ismokerice's Avatar
I say go with the Mr. Gasket copperseal and locking bolts. The paper gaskets seal up good, but don't seem to last more than a year or two. Plus once a small leak starts it burns out the gasket and you have to remove the headers, scrape, and replace em. I've had the same set of copperseals for a tad over 4 years now, and I've put em on several other vehicles too. Once in a while a small leak shows itself, just tighten back down and they seal again. Even if you tear down the engine for rebuild, or remove a header to access something, I don't see why you'd ever need to replace em.
They don't seem to seal right away though, you have to cycle them a few times. Torque the bolts, run up to temp and let cool, torque again. Do this 2-3 times then torque em down warm, I leave the locks out for like a week tightening the bolts every few days, then install the locks and no leaky headers. They don't take alot of torque, just "wrist-tight" with a small wrench each time.
Old Dec 20, 2005 | 09:28 AM
69z-28's Avatar
AHHH. i hate mixed responses. what about the Percy aluminum ones.
http://www.jegs.com/webapp/wcs/store...0259&langId=-1
i just want something that wont leak.
Old Dec 20, 2005 | 09:34 AM
Joe 1320's Avatar
These are killer. A stacked aluminum shim that won't burn through. They conform to irregular surfaces like warped header flanges on used headers Best you can get! I will never, ever use anything less than Percy's. I used Flepro 1406s and when I lost a stage 8 clip, the bolt backed out and the the gasket was toast. Never again. At least with these, if a bolt backs out you can simply retorque it and not have to replace the gasket. FYI, Autozone has them for the same dough.
Old Dec 20, 2005 | 11:09 AM
firebirdStud's Avatar
I use the mr gasket ultra seal gaskets. They are cheap, and have a metal core. They kick *** in my opinion! Like I said, they were cheap, and they work awesome. I got mine from Summit Racing. I don't know if you can reuse them, my first guess would be no, but I have not had to take my headers off to find out.
Old Dec 20, 2005 | 11:19 AM
walt355's Avatar
I have 2 freinds that used them, one on a 94 and the other on a 99. they both have worked the best. Thats what Im going with with my LTs this winter
Old Dec 20, 2005 | 11:27 AM
Deenasty's Avatar
no matter what people on here tell you, there is not going to be just one set of gaskets that have never failed anyone. Every header gasket has failed. There is no "eternal" gasket. For example the design of the percy's seems really great, yet they failed on me. I have had the best luck with the Felpro 1406 sprayed with copper seal, and 1" long ARP header bolts.
The bolts is were people go cheap. If the bolts back out, any gasket is gone. Make sure you use ARP 1" long bolts and heat cycle them. Bolt them in (from center bolts work your way out) Example cylinder's 3 and 5, than 1, 7. After you heat them up, let them fully cool, and then retighten. This will cause them not to back out. Dont waste your time on those silly stage 8's.
Old Dec 20, 2005 | 11:47 AM
wrd1972's Avatar
Fel-pro 1406 here and no leasks.
I did not use any spray sealer.
If I do encounter a leak and have to replace I will try the copper sealer.
Old Dec 20, 2005 | 01:20 PM
2000GTP's Avatar
I vouch for this one as well.
