Motor mounts
Old Dec 21, 2005 | 11:13 PM
Quickss96's Avatar
Motor mounts
What are the best motor mounts to buy. I have the motor out i might as well replace those too.
Old Dec 21, 2005 | 11:22 PM
3gc's Avatar
3gc
Re: Motor mounts
There aren't that many options. OEM replacement, parts store replacement and poly mounts. The poly mounts will give you a slight vibration at idle, some may be able to live with, but it if you want your car to feel like a caddy then your probably better off with the OEM. I went with energy suspension poly mounts and they don't vibrate all that much, i'm happy with them. They are also about half the price of OEM ones.
Old Dec 21, 2005 | 11:58 PM
97formula808's Avatar
Re: Motor mounts
i have the prothane mounts and they dont vibrate as everything think they would. i also have the tranny mount. theyre great.
Old Dec 22, 2005 | 12:16 AM
Quickss96's Avatar
Re: Motor mounts
are they better for more horse power? or what is the difference?
Old Dec 22, 2005 | 01:12 AM
LT1 POWR's Avatar
Re: Motor mounts
The poly ones are stiffer so they dont let the engine move as much. They are a must for vehicles with higher hp. They also last longer than the stock rubber ones and wont sag after years of use. I have the poly tranny and motor mounts and they dont vibrate any worst that stock, a little less i think.
Old Dec 22, 2005 | 07:47 AM
2000GTP's Avatar
Re: Motor mounts
I also got the Prothane Poly Mounts and I paid around 45.00 bucks for the pair. You can't beat that price as I'm pretty sure the stock GM mounts cost alot more then that.
Old Dec 22, 2005 | 02:41 PM
Quickss96's Avatar
Re: Motor mounts
where can i buy the poly mounts at?
Old Dec 22, 2005 | 02:49 PM
CamaroBoy96Z28's Avatar
Re: Motor mounts
www.thunderracing.com and I'm sure a few other site sponsors carry mounts as well.
Old Dec 22, 2005 | 03:48 PM
BlackScreaminMachine's Avatar
Re: Motor mounts
I bought new OEM mounts when the 383 went in. I had no issues with them and they have worked flawlessly since I have had them in there
Old Dec 22, 2005 | 07:24 PM
walt355's Avatar
Re: Motor mounts
I bought a set of Moroso solid mounts. The viberation is not as bad as I thought they would be
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
