Motor mounts
Old May 10, 2005 | 04:09 PM
IXLR894Z28's Avatar
Motor mounts
Hard to change?
Old May 10, 2005 | 05:04 PM
89385formula's Avatar
Re: Motor mounts
I guess it depends what you would consider hard. I did mine when I had the headers out, and the tranny out for a clutch swap. They were pretty easily actually....if you have headers...especially LT's it will not be fun for you.
Old May 10, 2005 | 05:09 PM
FIREHAWK #7's Avatar
Re: Motor mounts
its a pain in the a$$.... but well worth it. IT stopped my car from rattling when i would take off. good luck
Old May 10, 2005 | 05:10 PM
Compstall's Avatar
Re: Motor mounts
Originally Posted by 89385formula
They were pretty easily actually....it will not be fun for you.
Hey where's the Z been lately? I haven't seen it at your work in a while...
I'm taking leave next week and will be doing my cam swap.
Old May 10, 2005 | 05:14 PM
IXLR894Z28's Avatar
Re: Motor mounts
It got a new rear end in it and now a bushing in the rear of the tranny is being replaced. They have to have one made because GM mad it a non replaceable part, so I'm waiting on the machine shop. Once I get it back, are we on for the intake seal?
Old May 10, 2005 | 06:12 PM
Compstall's Avatar
Re: Motor mounts
Yep, just have to juggle a day in there. I figure I should be done no later than Tuesday if all goes well with the cam swap. It will either run like a bat outta hell or it won't run at all...who knows, this is my first time changing a cam in a V8 car.
Old May 11, 2005 | 07:02 AM
IXLR894Z28's Avatar
Re: Motor mounts
I,m going to get the stuff this weekend, and I'll let you know. What size cam are you putting in?
Old May 11, 2005 | 08:22 AM
Compstall's Avatar
Re: Motor mounts
Hotcam. BTW, most of the replies I've seen on this board since I've been on it regarding motor mounts is they're a PITA. But, if you've changed spark plug wires and plugs on these cars, how hard could it be....hehe
Old May 11, 2005 | 08:26 AM
94zgreenmachine's Avatar
Re: Motor mounts
Originally Posted by IXLR894Z28
Hard to change?
Are you using the stock mounts from the dealer? I am not sure if they sell the entire thing as a unit or if they just sell the inserts. If you are going to use the poly mounts, then you will have to drill the "rivets" out and seperate the plates to get the mounts out. Prothane makes a kit, I believe Part3 508 thru summit for 39.95. It will come with the necessary hardware and destructions to do the job.
Old May 11, 2005 | 10:46 AM
Re: Motor mounts
yes i also bought the Prothane mounts from www.thunderracing.com and i have changed spark plugs, wires, opti sparks, LT's, catbacks, and I thought that the were a pain in the ***.... Yes you have to drill out the rivets, that was easy, the only hard part is that I couldnt align the 3 bolts that bolt-on to the K member; maybe its because i was doing it by myself???? other than that if you have a buddy there it should be fairly easy.... ENJOY
Old May 11, 2005 | 10:49 AM
turbo_Z's Avatar
Re: Motor mounts
I didnt think they were that bad had I not messed around trying to get out. I was determined to get the bushing out of the mounting bracket w/o unbolting the bracket from the block b/c I believed it would be a PITA that way.. well I found out its the only way and really is quite easy. The only other hard part and probably the worst step of the entire process is getting that large bolt back thru the mount... i had a hell of a time lining it up perfectly. good luck! btw I went with the prothane mounts
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
