Motor Mounts
Old Oct 7, 2004 | 02:11 AM
SS1304's Avatar
Motor Mounts
Is there a place to get a how to on changing these? I have a set to put in that I need to put in, and when I was putting the headers in I noticed that the passenger side motor mount the bolt that goes through it hits from what I can remember the air conditioning tube or somethign.
Old Oct 7, 2004 | 06:47 AM
teke184's Avatar
Re: Motor Mounts
it's pretty obvious....jack the motor up to get room and start removing bolts.
have fun with those headers in...i know it took me 10hrs with manifolds, and when i installed headers there was no way i would have been able to do it
Old Oct 7, 2004 | 09:15 AM
TQdrivenws6's Avatar
Re: Motor Mounts
With my LT's in, it was 2 hours tops from jacking it up to test drive time??? I suppose if you don't have any tools ready or decide to drink a case of beer and eat a pizza or two it could take alot longer, but 10 hours??
Old Oct 7, 2004 | 09:19 AM
TobyZ28's Avatar
Re: Motor Mounts
Well it took me "3 days" to do my plugs, or 2-3 hour spread out over three days... so i can believe 10 hours at home on the driveway with little or no help
Old Oct 7, 2004 | 09:28 AM
96ZRide's Avatar
Re: Motor Mounts
I had to bend one of the AC tubes a tad to get to the passenger side Motor mount.
I don't remember it taking a whole lot of time to replace them.
Good luck!
Old Oct 7, 2004 | 10:02 AM
rocmemphis's Avatar
Re: Motor Mounts
I don't think there is a how to on the motor mounts. Once you get in there it is pretty easy to figure out how they come out. Have fun...it is a pain in the ****.
Old Oct 7, 2004 | 10:32 AM
badazzcamaro97's Avatar
Re: Motor Mounts
What I remember taking me the longest was grinding out the rivets to put the new mounts in the bracket.
Old Oct 7, 2004 | 10:53 AM
madwolf's Avatar
Re: Motor Mounts
It shouldn't take very long unless you run into alignment issues like I did. The driver side mount was pretty quick. It took me longer to drill out and reassemble the mount than to install it. The passenger side was a PITA though. The engine would simply not align itself to the mount holes. I beleive I had to disconnect the tranny crossbrace to get it to fit right.
Old Oct 7, 2004 | 01:36 PM
SS1304's Avatar
Re: Motor Mounts
OK, I will probally just end up taking out the entire assembly and doing it outside of the car and then putting it all bakc together. We will see how that goes.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
