motor mount shells
Old Feb 16, 2006 | 08:21 PM
Chevycobb's Avatar
motor mount shells
ok, I know one side has rivents that need to be drilled out, and the other doesn't. So am I supposed to just be able to pry the shell apart? because it does not want to seperate.
Old Feb 16, 2006 | 09:03 PM
silverz28's Avatar
Re: motor mount shells
Drill the rivits out. Then the shell will come apart.
Old Feb 16, 2006 | 09:23 PM
Jeff H's Avatar
If you didn't get the entire rivet out it will still hold together. I had to get a bigger drill bit to get the rest of the rivets to finally give up. I still had to pry it apart pretty good.
Old Feb 16, 2006 | 10:31 PM
69z-28's Avatar
i ground the rivets off with a mini grinder. both sides need griding, but the drivers side actualy bolts together then bolts back in place, whereas the passenger side you set in the shells together and bolt the two peice back to the frame.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Red_94Formula
Mar 7, 2015 09:21 AM
Nostang 96z
Aug 31, 2002 12:01 PM
