motor mount replacement
well for the past week or so i have been getting a vibration in my car. i had just gotten a magnaflow exhaust put on and i thought it may have been that since the guy that installed it is a hack... but then my dad took a ride with me in the car and stated that he thought i might have a bad motor mount, and today when i was driving i took of fairly hard and heard a bang so i jacked up the car, i spot the passanger side mount, it seems fine. then i go to find the drivers side and it is no where to be found i ran my hand along the cross member where i thought i should be in relation to the other one and there was nothing there i ran my hand along the whole side of the motor nothing! so on a scale of 1-10 how hard of a job am i looking at 1 being washing the car and 10 being installing headers. also can someone please post a step by step procedure for it
Guest
Posts: n/a
motormount
u are vey luck the driver side is the easiest side.. Take out center bolt first and then unbolt motor mount bracket off the block make sure u have a jack under it so its supported and just put the other mount in. i would give it on a scale 1-10 about a 4 for driver side. Now on the passenger side i would give it a 7
10-31-2016 11:09 AM
1LEThumper
07-14-2003 12:45 PM
