motor mount-to-block...where does the stud go
I just need to know the location of the stud when bolting the motor mount brackets to the block. I am pretty sure it is the forward most hole, but not sure if it is on the drivers or passengers side of the block.
thanks
thanks
Re: motor mount-to-block...where does the stud go
I believe the one you are talking about is this one http://shbox.com/1/battery_cable_ground.jpg . Hope this helps. And also, this is on the passenger side.
