Motor going in from top... couple questions :)
Old Jul 22, 2005 | 05:02 AM
Black1995Z's Avatar
Lightbulb Motor going in from top... couple questions :)
Should I put the alternator on in the car or out?
Should I put the stock exhaust manifolds in the car or out?
Should I attach the wiring harness in the car or out?
Where to attach the chains? I dont want to damage the freshly painted motor
Should I put the stock y-pipe and cat on before I put the motor in?
Tips?
Anything I need to know before I fire it up? Priming oil pump, etc..?
This is my first time and I really need advice, so please be as helpful as possible
The tranny is already in the car, its just the motor going in and the radiator is already out.
Old Jul 22, 2005 | 08:48 AM
OBE1 95Z28's Avatar
Re: Motor going in from top... couple questions :)
The alternator easily installs after the motor is in. I leave everything off except the heads and intake when I install from the top. I use a Happy Hooker, a plate that mounts to the intake, to lower mine in the car. I bought it from TPIS years ago.
Old Jul 22, 2005 | 09:33 AM
blackztpi's Avatar
u can probably put your manifolds on, but i'd leave everything else out for now. its much easier to put it all on later, than try it and have it not work. eats gaskets, tears gaskets, and takes a while
jb4xx
Feb 2, 2015 10:00 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ChrisFrez
Jan 4, 2015 08:43 AM
Brent94Z
Mar 21, 2002 04:44 PM
