a motor full of water :(
Old Aug 13, 2004 | 06:39 PM
1badasZ's Avatar
Angry a motor full of water :(
im in the process of doing a head and cam change. my car has been sitting for about a year but have had the heads off for about 4 months. i got ready to drop the oil pan and i noticed some water dripping from the front of the pan where the timing cover meets. i thought maybe it was just some from on the motor or something but when i took the plug out of the pan out guess what came out the the my oil pump and the tips of the crank n rods have that oil/water mix on them... i didnt see any visual rust but i still know its not good. is there any way i can fix this without having to rebuild right now or am i screwed and sure to spin a bearing when i get ready to start it up?
Old Aug 13, 2004 | 06:45 PM
Spinner's Avatar
Re: a motor full of water :(
Probably just condensation. Get an oil squirter, and squirt it all down and spin it over a few times manually to be sure there's none up in there.
Old Aug 13, 2004 | 06:49 PM
1badasZ's Avatar
while i had the cam n stuff out i poured oil in the holes n stuff in the lifter valley but it just ran through. i was wandering about that though...if i just spin it over by hand for a while will the oil get back to everything it needs to. also would it help to put some lucas in it too?
Old Aug 13, 2004 | 07:11 PM
1badasZ's Avatar
any other suggestions or ideas?
Old Aug 13, 2004 | 09:09 PM
1badasZ's Avatar
ttt...come on now somebody out there help me out. i know someone has to know something i can try to clean all of this out or something. or if its a waste of time.. all you engine specialist give me a hand please. if i had posted something about needing a bigger throttle body or something simple like that id have a million responses
Old Aug 13, 2004 | 09:13 PM
dhirocz's Avatar
Get an oil pump primer and prime the oiling system...so this for awhile and spin it over. You may also want to pull the rod cap(s) that were submerged to check for signs of rust before doing that. If it checks OK then I wouldn't worry about it too much.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
Cam's maro
Jan 30, 2015 09:21 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
