Motive 3:73 question
Old Mar 16, 2003 | 09:55 PM
GreekZ's Avatar
will these gears be a direct replacement for stock 2:73 gears in a 95?
Old Mar 16, 2003 | 10:13 PM
GreekZ's Avatar
also what is the difference in 2 and 3 series carriers and how do you know which one you have?
Old Mar 16, 2003 | 10:41 PM
GreekZ's Avatar
anyone?
Old Mar 17, 2003 | 12:41 AM
smokindastangs's Avatar
Ummm, i think that i understand your question. The motive gears are basically GM gears.....and yes they will work.
Old Mar 17, 2003 | 12:46 AM
pennys58's Avatar
I thought the stock gears in a 1995 was a 3.23...that is what I had...maybe different for different cars
Old Mar 17, 2003 | 12:51 AM
I may be wrong, but i was under the impression that most A4's came w/ 2.73s and that the M6 came w/ 3.23's...don't hold me to that but i heard it somewhere.
Old Mar 17, 2003 | 12:52 AM
chesee48's Avatar
Best way to know for sure is to check your codes to make sure. But either way, a 3.23 to 3.73 upgrade is still worth it IMO
Old Mar 17, 2003 | 02:23 AM
Ernster500's Avatar
BTW, here are the RPO codes for the gear ratio:
GU2 Axle, Rear 2.73 Ratio
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
Old Mar 17, 2003 | 07:27 AM
94 NO TOP Z's Avatar
If you have 2.73's you will need a 3-series carrier to install them. Strange and Richmond make a 3.73 to fit your existing 2-series carrier but GM doesn't.
Old Mar 17, 2003 | 07:57 AM
ltlhomer's Avatar
If you have 2.73's (GU2 code in your glovebox or on your driver side door), then you have a series 2 carrier. Get the GM Motive 3.73's made for the series 2 carrier. That's exactly what I did and they are perfectly quiet and have held up to many a dragstrip pass. :-)
Old Mar 18, 2003 | 01:00 AM
pennys58's Avatar
I'm glad that you brought that up about the codes...I have no idea what I have. I can't wait to see
REDNECKISBOSS
Apr 17, 2015 07:14 AM
97bowtie
Aug 25, 2002 11:00 PM
86ZZ4
Aug 22, 2002 08:50 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
Camaro90RS
Jul 23, 2002 07:57 AM
