most reliable springs for le1 cam
Old Apr 25, 2006 | 02:05 PM
luckyou03's Avatar
should get installing the le1 cam and 1.6rr next week and i need to order some springs. This is a daily driven car so i am looking for reliablity. so what'll is be? behives, dual springs, cc918, cc987, cm 612?
Old Apr 25, 2006 | 02:35 PM
OldSStroker's Avatar
Re: most reliable springs for le1 cam
If you got the cam with LE1 heads from Lloyd the correct springs will come on the head. If you purchased the cam alone from a private party, you should probably contact Bret (SStrokerAce) for a spring recommendation.
Old Apr 25, 2006 | 03:38 PM
BlackScreaminMachine's Avatar
My cam from bret is a cross between a LE1-LE2, bret installed comp cam 918's and also did the installed hieght. Which came out perfect, prfect spring for aggressive cam lobes. Also with beehives it saves on valve train weight, even if steel retainers are used.
Old Apr 25, 2006 | 03:45 PM
luckyou03's Avatar
I was leaning towards 918's but the guy i bought it from broke a 918 spring in only 18 miles
Old Apr 25, 2006 | 03:49 PM
If installed spring height was not done, then any spring can coil bind and break. Just putting a set a springs in is not the proper way of doing it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
grabbem88
Feb 22, 2015 11:16 AM
donot_4get
Sep 14, 2002 08:03 AM
