most power n/a with LT4 intake?
Old Nov 17, 2003 | 03:37 PM
  #31
squinn's Avatar
Originally posted by got_hp?
wow........wait a min.......stock lt1 shortblock or built?
btw, your website isnt loading.
Reringed stock short block.
yes I know, I need to find a new place to put it
Old Nov 17, 2003 | 03:40 PM
  #32
kmook's Avatar
Advanced Tech Moderator
Originally posted by hsyr
Correct me if I'm wrong but I thought Mindgame had 18deg heads?
Nope 15*
Old Nov 17, 2003 | 03:53 PM
  #33
got_hp?'s Avatar
so your stock bottom end lt1, with ported lt1 castings and ported lt1 intake made 560 fwhp on a hydraulic roller cam?
i think that has to be a record or something.
you said you spun it to 7100.....so im guessing you had something other than the stock computer/optispark/ignition setup?
who ported the heads/intake?
my site is hosted by www.vnpixel.com , very reliable and decent pricing, check them out.
Old Nov 17, 2003 | 03:57 PM
  #34
chucks97ss's Avatar
I'm not trying to raise the bs flag... but that clearly is not what you told me about your short block a couple weeks ago. You said it's a 3.65 stroke crank. So the only things that could even remotely be "stock" are the rods. Whether you're running stock rods on a 600+ hp setup is beyond me, and really I don't care. Please clarify what you meant by this so that I can regain my trust in you stating that your car actually does have "GM cast LT1" heads and intake. That and/or WHY you're LT1 intake is so heavily modified (ie, little sneaky pete action).
Later
Chuck
Old Nov 17, 2003 | 04:03 PM
  #35
squinn's Avatar
Fast ecm with opti and a crank trigger.
we had ended up make 581 @ 7200 with a highly modified Lt1 intake on the same short block.
Modern Cylinder Head in the Detroit area did the heads
I do my own intakes.
Old Nov 17, 2003 | 04:06 PM
  #36
chucks97ss's Avatar
I apologize, I did not read the first post clearly... You're talking about 2 different motors. My bad...
Later
Chuck
Old Nov 17, 2003 | 04:14 PM
  #37
squinn's Avatar
Later
Chuck
the stock short block failed back in the spring of 2002, after that I finshed the 370 ci motor 4.03 x 3.625, this is the current motor in the car. I don't know how to prove that the motor does have gm cast heads, as far as the intakes goes it started as a gm casting, here is a link you can take a look.
http://community.webshots.com/photo/...99362750zgEpEj
Old Nov 17, 2003 | 04:27 PM
  #38
got_hp?'s Avatar
website or phone number for modern cylinder head?
any specs on the cam numbers or is it secret?
Old Nov 17, 2003 | 04:55 PM
  #39
squinn's Avatar
586- 468-7914
its a secret
Old Nov 17, 2003 | 05:32 PM
  #40
Cory1994z28's Avatar
flow #'s
what kind of numbers do your heads flow... and could you tell us a little more about your intake. If your cam is a "secret", could you just give us an idea of how big the lift and duration is.... just a clue for us little guys, please
Old Nov 17, 2003 | 05:56 PM
  #41
got_hp?'s Avatar
Re: flow #'s
he said earlier, gm LT1 casting that flow 276 @ 600
Old Nov 17, 2003 | 06:02 PM
  #42
squinn's Avatar
Re: flow #'s
heads are nothing crazy 276 @ 650 on int and 190 @ 650 exh
that cam is something like chuck's
Old Nov 17, 2003 | 06:10 PM
  #43
chucks97ss's Avatar
Re: Re: flow #'s
What influenced you to stay with the stock castings?
Later
Chuck
Old Nov 17, 2003 | 07:05 PM
  #44
squinn's Avatar
back in 97' when I had the heads done I was building the car for NSCA EFI class, this was a factored index class, much diffrent then it is now in the NMCA. I think the AFR had just come out, the heads have worked good, so I stayed with them.
Old Nov 17, 2003 | 07:24 PM
  #45
chucks97ss's Avatar
I gotcha... so when are you going to put some AFR's or something on there?
Later
Chuck
