Most HP gain for 350 dollar
Re: Most HP gain for 350 dollar
you can get a more aggessive cam for way under $350 and maybe a chip or K&N probably would yield more then just new headers. From dyno tests I have seen the the stock headers while not great arn't too shabby.
Buy summit 1.6 roller tip rockers for $99 part# sum-141507, guide plates from summit for sum-g6451 for $17 and send you ECU to Mad z28 tuning for $80. Thats $196 and the four dollars will buy you two double cheeseburgars and a coke form McDonalds.
Yes they will work fine, actually they are designed to work with stock springs.
Hard to say because I did a lot more than just rockers. I think that you would have to do more than 1.6 rockers to get the springs to bind. When that happens it usually from people putting in a different cam and using stock springs.
