Moroso vs. K&N Air increase
Old Feb 2, 2003 | 09:44 PM
94_Z28_guy's Avatar
Looking in back of my Summit catalog:
There is a K&N air flow increaser ($205) and a Moroso ($190). Which is better? Thinking about getting one.
(One the side: are these good prices?)
Old Feb 2, 2003 | 09:49 PM
warner's Avatar
For performance they're about the same. You should be able to find a used one for much less money.
97droptopZ's Avatar
pretty good prices, go w/ the k&n, its a better brand but then again ive never tried moroso
u can get the k&n for 190 + shipping here tho http://www.lt1f-body.racenet.net/induction.php
Old Feb 2, 2003 | 09:56 PM
BPS's Avatar
BPS
from what I've read the K&n is a little better - both are a big improvement
Old Feb 2, 2003 | 10:00 PM
94_Z28_guy's Avatar
Thanks a lot !
Are the filters cleanable? If not are they easy to buy separate?
Old Feb 2, 2003 | 10:01 PM
Jcb890's Avatar
i've heard from many many people that all of them are basically the same (SLP, K&N, Moroso, Lingenfelter, etc.) except the G2 one is not worth it and the others outperform it...
Old Feb 2, 2003 | 10:05 PM
madwolf's Avatar
You can make a filter look like brand new with a K&N Recharging kit which is about....$12 or so?
If I were you, I'd buy a used one. They usually go for much cheaper. It's just a piece of plastic anyway.
Old Feb 2, 2003 | 10:12 PM
Trans AM 22502's Avatar
When it comes to intakes, everything with the exception of the G2 is the same. I went with a Moroso and K&N Air filter, it really doesn't matter though.
Old Feb 2, 2003 | 10:26 PM
97droptopZ's Avatar
the k&n comes w/ a cleaning kit...well at least mine did
Old Feb 3, 2003 | 06:53 AM
IDOXLR8's Avatar
IMHO I have had the K&N CAI but if I had to do it all over again I would had gone with the MOrroso.
Old Feb 3, 2003 | 09:07 AM
redcamaroz28's Avatar
I've got the Moroso. I agree with everyone else that they're all pretty much the same. I'm sure one out-performs the others by a little, but you won't know this unless your car is pulling in all the air around it . I could definitely feel the difference when I put my cold air on, so I recommend the moroso. (It is easy to install. It took me 20 minutes to install, but 10 of these minutes was trying to put the stupid bolt on, which wouldn't line up cause i drilled the hole in the wrong place )
Later
Ryan
Old Feb 3, 2003 | 09:16 AM
LimitedEd1LE's Avatar
My buddy has the Moroso one and it was much easier to install it all. When I installed my K&N one, I had problems getting the cone to kit onto the plastic piece. They're both going to be better than stock air flow.
Old Feb 3, 2003 | 11:12 AM
Javier97Z28's Avatar
Moderator
they're all the same power wise, but the SLP looks 12342908762310947324x better
Old Feb 3, 2003 | 11:14 AM
chesee48's Avatar
i'd get a SLP one....
they look better
Old Feb 3, 2003 | 11:45 AM
TedH's Avatar
I have the Moroso. I bought it because Moroso has been around the drag racing community for years. I don't think there is much difference between the Moroso and the K&N. I use the K&N cleaning stuff on the Moroso.
DirtyDaveW
Dec 1, 2016 05:37 PM
thenewkid
Apr 12, 2015 07:42 PM
NewsBot
Jan 29, 2015 07:10 PM
95chwagon
Jan 13, 2015 09:19 PM
thenewkid
Nov 27, 2014 09:41 AM
