moroso cold air
Old May 19, 2008 | 10:45 AM
remy2435's Avatar
moroso cold air
hey i just purchased an moroso cold air for my 97 z, and i wondering if any one has one and if so what changes in hp/trq/mpg are you experiencing.
Old May 19, 2008 | 10:54 AM
CheshireCat's Avatar
I think that the general consensus is that a CAI will give you 5-10 HP on a stock motor.
Just keep in mind that it only gives you that added HP potential at WOT. Any time the throttle blades aren't wide open, they are going to be a bigger restriction than your intake.
Old May 19, 2008 | 02:32 PM
Mtxz453's Avatar
nice bolt on for both hp and mpg. you'll notice a little better responce when you hit the petal
Old May 19, 2008 | 02:39 PM
bombebomb's Avatar
I noticed nothing from my CAI. I guess 5-10whp on a 240hp car just is not a big enough deal for SOTP feeling.
Old May 19, 2008 | 03:06 PM
wrd1972's Avatar
I would agree with this.
Old May 19, 2008 | 08:55 PM
Jay97's Avatar
I had a home made one on the car when I got it, not a bad set up, but filter hung level with radiator so not really getting "cold air". One of my mechanics had a new Moroso unit in the box and I got it for 100.00 and put it on today. Mine is a modded 383 so not stock, but can tell you I noticed a difference in a correctly designed CAI. The moroso has the bracket that isolates the filter below the core support where it can get air off the dam. I cut the corner piece off the facia underneath to give a open hole to the filter.
I really did notice seat of the pants feel off of it. Also make sure the elbow you use from it to intake is a smooth transition and all pipes/tubes are clear paths with the couplings. Anything that makes the air move into an obstruction defeats the whole idea.
Old May 20, 2008 | 08:01 AM
2000GTP's Avatar
The gains will be there, just not enough to notice. You'll probably notice a little more noise in the intake.
Old May 20, 2008 | 11:32 AM
LT1Camarogirl's Avatar
thats all i really noticed when i got mine on...good mod though
Old May 20, 2008 | 01:34 PM
I've heard people say that a CAI will improve MPG, but for the life of me, I can't figure out how...
Old May 20, 2008 | 01:58 PM
bombebomb's Avatar
More complete combustion is my guess.
Old May 20, 2008 | 04:28 PM
Virtually all the theory I've read indicates that warmer air will result in a more complete combustion and thus more efficiency. Colder/denser air will result in more power due to the greater oxygen content per volume. Of course, the 02 sensors adjust and throw in more fuel. So that should result in more power but lower MPG.
thenewkid
Apr 12, 2015 07:42 PM
Britbilly
Jan 7, 2015 08:49 PM
thenewkid
Nov 27, 2014 09:41 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
SABLT194
Aug 3, 2002 09:33 AM
