moroso cai cleaning? replacement filter?
Old May 27, 2004 | 09:20 PM
MarkyMark's Avatar
Go
I was wondering if the filter on the moroso cai can be cleaned and recharged and if not then where can I buy a new filter?
________
Velary
Old May 27, 2004 | 11:36 PM
It should be the gauze K&N. If so, it can be cleaned and "carefully" reoiled.
Old May 27, 2004 | 11:39 PM
OBE1 95Z28's Avatar
Carefully oiled as in don't over oil it. Too much oil will end up coated your MAF and screwing up your air/fuel ratio.
Old May 27, 2004 | 11:47 PM
MarkyMark's Avatar
Go
Hmmmmm.........thanks for the info........it has about 5-7k miles on it and maybe 7 or 8 months of actual driving........do you think it even needs cleaned. I havent had a chance to take it off and look at it, but I just trying to clean everything up so I can run a better time at the track, but after reading a few other posts I'm not sure if I should even mess with it......or maybe I will use some compressed air and blow the dirt out and leave it without washing.
________
Emanuel4u
Old May 28, 2004 | 12:11 AM
The K&N gauze type filters work better with a thin coat of dirt. K&N recommends a 50K mile cleaning interval, but you could shorten that if you routinely operate under dirty or dusty conditions.
Old May 28, 2004 | 12:19 AM
MarkyMark's Avatar
Go
I am contemplating doing the free ram air mod which I know the gains are debatable, but I have lots of time and get bored during the day. I figured the open hole will make it get dirty much quicker, so I figured I would need to clean it before I went to the track the next time. I read that thing k&n said about it being better when a little dirty somewhere also......doesnt make a whole lotta sense to me though.........
________
GLASS BONG
Old May 28, 2004 | 10:20 AM
Here's a link to a very well done test on oiled gauze, oiled foam and paper filters. It is for motorcycles, but the principles are the same. I like this sort of test, because it isn't like the manufacturer's tests (K&N, Amsoil, etc) that are generally rigged to give the results the manufacturer wants.
http://www.ibmwr.org/otech/airfilter.html
The K&N was shown in the independant test to filter better with a coat of dirt on it. K&N's own filter efficiency tests are apparently conducted in this condition.
Another thought.... the K&N can only be "washed' 25 times. After that, K&N recommends that it be discarded, since it has lost its filtration efficiency.
After you read the article in the link, you might be rethinking filter choice.
Old May 28, 2004 | 06:57 PM
MarkyMark's Avatar
Well I didnt read the whole thing, but i read a few parts and what i gathered was that the k&n will filter more effeciently and get more particles when a little dirty, but I really dont care much about that and I want the best flowing filter possible. I would think it would definately flow the best when clean and brand new, but when a little bit dirtier it will filter more and let less dirt in. Am I right? I didnt really see much about flow in the article but I would think a clean over dusty/dirty filter would flow better.
Who knows though, the gains or differences between being a dirty or clean one are probably very minimal and wouldnt even be noticed.
Old May 28, 2004 | 10:41 PM
96ss2nv's Avatar
Definately don't use pressurized air to blow it out. It'll tear tiny holes in the fabric that'll let dirt through. To tell ya the truth, I buy a new K&N once a year without ever cleaning it. I'm afraid if I cleaned mine, I'd use too much oil and have MAF problems down the road. It's ony like $40 a year anyway.
Old May 28, 2004 | 11:10 PM
Jabberwocky's Avatar
I think it is pretty safe to clean it, plus it is cheaper. I have the SLP intake which has 2 cone filters, buying a set of new cones would cost too much. One cleaning kit is good for many uses.
Old May 29, 2004 | 04:17 PM
MarkyMark's Avatar
Well, does anyone know the part number for the replacement filter on the moroso? I wouldnt even know which one to get or which one would fit....
ScottZ
Mar 3, 2004 01:34 PM
troywg
Sep 12, 2002 07:28 PM
Teal94V-6
Aug 31, 2002 09:21 PM
TheV6Bird
Aug 27, 2002 10:38 PM
jim88iroc305
Aug 13, 2002 09:24 PM
