more problems: oil pressure and rockers
Old Jan 5, 2008 | 11:47 AM
  #16
nes's Avatar
nes
well looks like ill have it in the shop the next couple weeks
Old Jan 5, 2008 | 01:10 PM
  #17
Wild1's Avatar
As you know, oil is a serious thing. If you are handy with tools you can try to isolate the concern. Remove the fuse to the PCM (no spark or fuel) and remove the oil filter. Crank the engine 2x. Oil should be gushing out the filter adaptor.
If not, then it is between the pickup or oil pump. Drop the pan and get a new pump and clean the pickup.
If you do get oil, then your blockage is further up the oil galleries.
An option is to remove the oil pressure sending unit. Don't crank the engine much or you will cause further damage.
Old Jan 5, 2008 | 01:51 PM
  #18
nes's Avatar
nes
man, yall are realy helpful, thanx
Old Jan 5, 2008 | 02:39 PM
  #19
Wild1's Avatar
This is by far my favorite website and forum for true enthusiasts. Good luck, let us know how this goes.
Old Jan 8, 2008 | 01:22 PM
  #20
nes's Avatar
nes
just got it to the shop, will find out tomarrow...
and on the way there, i noticed the valvetrain isnt as loud as it was when it overheated, my guess is i have a blown headgasket and cracked head but im unsure...
Old Mar 12, 2008 | 01:27 AM
  #21
Oxygen454's Avatar
Any update? Curious on your oil problems...
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
