more oil problems
Old Oct 17, 2005 | 07:17 AM
theonly95SS's Avatar
more oil problems
ok, i have a freshly rebuilt LT1 with GTP custom cam and a melling HV oil pump, i did replace the pump shaft with the ARP hardened one and i got the larger pickup to go with the melling pump, and now when im at a light (forgive me i dont know the numerical equivilent for the lines on the stock gauge) it will be just above the first orange line, and when i am driving normal it gets just below the first white line and when i get on it it gets just above the first white line. i scanned it and it didnt say anything about the sending unit being bad. when i get in the car in the morning and the motors cold i have good pressure but as it warms up i loose it all, i changed the oild in hopes that would fix it but it didnt help at all. im not driving it anymore because i had the motor rebuilt due to sudden oilpressure lost, and spun 4 or 5 bearings, so this problem reallllly has me concerned. any thoughts?
also ment to add, when the motor was rebuilt, i had it machined and the clearences checed and it was all fine, i also had new clevite bearings installed all around, theres no shavings in the oil and theres no metal on metal sound. unfortunantly i know all to well the sound of a spun bearing and i dont hear any of that
Old Oct 17, 2005 | 11:07 AM
moparman's Avatar
Re: more oil problems
What kind of oil are you using?
Old Oct 17, 2005 | 11:25 AM
i dunno whatever brand 10w-30, would that make a difference? i was holding off on going mobile1 until i got the first 1000 miles on the motor
Old Oct 17, 2005 | 11:27 AM
Gripenfelter's Avatar
Are you using a larger oil pan with that HV pump? If not, you could starve your motor of oil. It happened to me and I have 8 scored piston skirts and one spun rod bearing to prove it.
Old Oct 17, 2005 | 12:16 PM
oh god, i got an HV oil pump to save me from my last disaster of loosing almost all my bearings, and now thats going to be what causes it?!
Old Oct 17, 2005 | 01:45 PM
1racerdude's Avatar
Put a manual guage on it and see what it says.
Not likely to have starvation problems at idle or cruise.
Old Oct 17, 2005 | 01:53 PM
race24x's Avatar
Correct me if I am wrong but shoudl he have installed a high pressure oil pump rather and I thought there was a difference between a high pressure and a high volume oil pump????
Old Oct 17, 2005 | 02:36 PM
i was told high volume was the way to go not high pressure
Old Oct 18, 2005 | 06:26 AM
race24x's Avatar
That could be I am not that knowledgable about built engines I have someone do mine and he recommends whatever I need and then I assemble it myself. My stock car only had a 7 quart pan and he recommended a high pressure as he mentioned a high volume could empty the pan and run dry before the oil made it back down. We did clean up the oil return holes etc but you run a stock car motor from 4-6000 around the track it may be different than a drag or street motor.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
artic94
Jan 17, 2015 11:19 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
