More Longtube question...
Old May 9, 2003 | 02:43 PM
94ZVert's Avatar
KBDD SFC's and Longtubes...
Couple quick questions for those who have Jet-Hot or Hooker LT's. First, what did you use to seal the connection between the driver's side header that comes apart. (i.e.- one of the primaries comes off and has to be installed onto the header.) Also, anyone running Kenny Brown DD SFC's with their longtubes? With the Y-pipe up there it doesn't look like there will be enough room in there. Thanks for any help.
Old May 9, 2003 | 03:39 PM
tom3's Avatar
I used a home depot part that is meant to connect pipes together. Check in plumbing; it comes with a rubber part you have to discard.
I did some pics for somebody else a while back; check the archives, maybe there is still something about it
Old May 9, 2003 | 03:47 PM
GetaZforgetGT's Avatar
I just scuffed mine up with some sand paper...removing some of the coating and forced the two together with a twisting motion.
It takes some effort but it won't leak then.
Old May 10, 2003 | 09:54 AM
94ZVert's Avatar
Is anyone running KBDD SFC's and Longtubes with the Mufflex Y-pipe?
tdigger9899
Sep 7, 2015 10:56 AM
97SSdude
Aug 21, 2015 09:36 AM
jbc3
Jul 28, 2015 12:24 PM
mrwz28
Jul 8, 2015 09:11 PM
