more fuel needed for a 93 LT1 with a 227/233 comp XE cam?
Old Mar 31, 2004 | 02:52 PM
sc93's Avatar
Exclamation more fuel needed for a 93 LT1 with a 227/233 comp XE cam?
Would I need an AFPR for my 93 with this cam? Or is the stock fuel supply sufficient?
Old Mar 31, 2004 | 03:04 PM
R_Andersen's Avatar
The stock fuel pressure regulator is fine, but you will definately need the computer programmed for that cam. I'm running a 230/236 cam in my 93 and it took some major changes in the VE tables to get it running properly.
-Rob
Old Mar 31, 2004 | 03:16 PM
sc93's Avatar
I had Alvin at pcmforless do a tune for me, so I assume everything there was taken care of.
does the programming actually allow the computer to tell it to supply more fuel?
Old Mar 31, 2004 | 03:19 PM
speedmiser's Avatar
Yep...
Old Mar 31, 2004 | 03:20 PM
sc93's Avatar
Originally posted by speedmiser
Yep...
Yep to what? I asked more than one question
Old Mar 31, 2004 | 03:36 PM
speedmiser's Avatar
I answered the last question you asked...
<<does the programming actually allow the computer to tell it to supply more fuel?>> - Yep...
As far the first - you probably dont need a adjustable fuel regulator, unless you're current fp is to high or low. You can ask your tuner at what fp he turned for, then check to see if that's what you have.
Old Mar 31, 2004 | 03:55 PM
sc93's Avatar
Cool, thanks.
my friend insists that I NEED an afpr to bump up my pressure for this cam.
Old Mar 31, 2004 | 04:00 PM
RichWhalen's Avatar
I've been tuning a friend's car that has this cam. He has stock heads, but a full exhaust with headers. We are seeing injector duty cycles over 90% above 6200 rpm. This is at stock fuel pressures. It would not hurt to raise your fuel pressure if you are going to stick with the stock injectors.
Old Apr 1, 2004 | 10:19 PM
speedmiser's Avatar
I'd assumed that if Alvin tuned it, he didnt let the duty rates get to high. Ask him, before you go messing with the fuel pressure. If you do ending up raising the fuel pressure to lower the duty cycle, you're going to need to have him cut a new chip.
Old Apr 1, 2004 | 10:43 PM
sc93's Avatar
Yeah, I'm gonna give him a call tomorrow.
Old Apr 1, 2004 | 11:21 PM
justens95z's Avatar
so then, would you guys think I would need bigger injectors or AFPR for my car with a CC306 cam with stock heads and cold air and big TB and exhaust?
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
GigaMp3z
Feb 20, 2003 02:57 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
