More Beautiful work by Lloyd Elliott
Old Aug 16, 2005 | 11:37 PM
blackz97's Avatar
And heres the rundown. Check out the big lift #'s !
.2 142/108
.3 193/143
.4 239/169
.5 271/185
.6 283/197
.650 286/201
Nice!
Stephen
Old Aug 16, 2005 | 11:40 PM
fokwolfe95's Avatar
Re: More Beautiful work by Lloyd Elliott
Nice indeed! Are these LT1 castings? Which package?
Old Aug 16, 2005 | 11:46 PM
blackz97's Avatar
Aluminum LT1 castings, LE3 package.
Old Aug 17, 2005 | 12:15 AM
zbomb5610's Avatar
i agree, lloyd does amazing work, i had him port my lt1 trickflow heads and they came out awesome.
Old Aug 17, 2005 | 09:04 AM
zhevy-1's Avatar
What kind of power are you putting at the wheels?
Track times? Just curious about those TF Heads.
-Goose
Old Aug 17, 2005 | 09:06 AM
Valkyn71's Avatar
Wow, those are the best numbers ive seen from LT1 castings!
(not that i look at them all that much)
Lloyd is definetly a great guy.
Old Aug 17, 2005 | 06:14 PM
NightTrain66's Avatar
Those heads are LT1 castings but have larger valve seats installed to accept 2.05/1.60 valves. This is a pretty big port (207 cc) and needs to be on a 6800 RPM 355 or 6500 RPM 383 in a car with some gear and stall to work well.
You would NOT want these heads on a stock bottom end with a Hot Cam in a 3800 lb F body with 3.42 gears and a mild stall.
A 3500 lb F body with a 355, 4.11's and 3600 stall would make a great home for these heads and my LE3 cam. A 383 can get away with a lil less gear and stall.
Lloyd Elliott
972-617-5671
Eportworks.com
Old Aug 17, 2005 | 07:33 PM
stew's94z's Avatar
Another satisfied customer.
Keep up the good work Lloyd.
Dean
Old Aug 17, 2005 | 07:50 PM
zbomb5610's Avatar
-Goose
still don't have the block in yet, should be in the car tomorrow, everything should be finalized by friday.
ill definitely post up some info when i get the car dynoed.
Old Aug 18, 2005 | 12:08 PM
pntballty's Avatar
Nice numbers, ours are very close. LE 3's Also
.2 138/107
.3 198/142
.4 242/169
.5 273/184
.6 282/194
NewsBot
Jan 23, 2015 01:10 PM
Collector Car
Jan 5, 2015 10:58 AM
92ragtop
Dec 27, 2014 01:56 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
