More Beautiful work by Lloyd Elliott
Re: More Beautiful work by Lloyd Elliott
Originally Posted by zbomb5610
i agree, lloyd does amazing work, i had him port my lt1 trickflow heads and they came out awesome.
Track times? Just curious about those TF Heads.
-Goose
Those heads are LT1 castings but have larger valve seats installed to accept 2.05/1.60 valves. This is a pretty big port (207 cc) and needs to be on a 6800 RPM 355 or 6500 RPM 383 in a car with some gear and stall to work well.
You would NOT want these heads on a stock bottom end with a Hot Cam in a 3800 lb F body with 3.42 gears and a mild stall.
A 3500 lb F body with a 355, 4.11's and 3600 stall would make a great home for these heads and my LE3 cam. A 383 can get away with a lil less gear and stall.
Lloyd Elliott
972-617-5671
Eportworks.com
Lloyd Elliott
972-617-5671
Eportworks.com
Originally Posted by zhevy-1
What kind of power are you putting at the wheels?
-Goose
-Goose
ill definitely post up some info when i get the car dynoed.
NewsBot
Jan 23, 2015 01:10 PM
