more air/fuel
Old Oct 19, 2005 | 09:52 PM
Notacamaro's Avatar
more air/fuel
So, will putting a bigger throttle body and bigger fuel injectors on a internally stock motor yield any results, or does it have all it needs?
Old Oct 19, 2005 | 10:02 PM
Re: more air/fuel
A larger throttle body will not provide any significant increase in air flow on a relatively stock engine. Since you won't see any added air flow, you won't need any added fuel. In practical terms, you might see a small decrease in pressure loss across the throttle blades with a larger diameter throttle body, but I doubt you would see more than 5HP on a good day. The stock injectors can easilly handle that small increase.
RUENUF
Mar 13, 2016 03:37 PM
Aug 7, 2015 01:26 PM
BlackZin01
Aug 11, 2003 12:41 PM
dayusmc
Oct 2, 2002 07:16 AM
ROCKN SS
Jul 29, 2002 05:22 PM
